I am facing a problem when an ESP module stops responding after some hours of operation. It pass from a couple of hours to 2-3 days before it happens. The module reads temperature data from a ds18b20 sensor every 5 seconds and calculates timeON for a relay. Furthermore, the module is listening to a port and sends the temperature data out (just a few bytes) on request over WIFI.
Trying to investigate it a bit, I to connected to a pc monitoring the output on UART. This is what I got from the terminal:
PANIC: unprotected error in call to Lua API (attempt to call a userd)
load 0x40100000, len 26896, room 16
tail 0
chksum 0x5b
load 0x3ffe8000, len 2208, room 8
tail 8
chksum 0xb7
load 0x3ffe88a0, len 136, room 0
tail 8
chksum 0xeb
csum 0xeb
����g��sッ�'|�
�l�xsd��r�l��
NodeMCU custom build by frightanic.com
branch: master
commit: b96e31477ca1e207aa1c0cdc334539b1f7d3a7f0
SSL: false
modules: adc,file,gpio,net,node,ow,pwm,tmr,uart,wifi,file,gpi
build built on: 2017-02-05 12:01
powered by Lua 5.1.4 on SDK 2.0.0(656edbf)I guess that the key phrase here is "attempt to call a userd", but googling it did not bring me anywhere.
Will appreciate if anybody shed some light onto this and point me in the right direction.
