The source code is from Thingsboard on github:
https://raw.githubusercontent.com/thingsboard/thingsboard.github.io/master/docs/samples/esp8266/resources/esp8266-dht-mqtt.ino
#include "DHT.h"
#include <PubSubClient.h>
#define WIFI_AP "YOUR_WIFI_AP"
#define WIFI_PASSWORD "YOUR_WIFI_PASSWORD"
#define TOKEN "ESP8266_DEMO_TOKEN"
// DHT
#define DHTPIN 2
#define DHTTYPE DHT22
char thingsboardServer[] = "YOUR_THINGSBOARD_HOST_OR_IP";
WiFiClient wifiClient;
// Initialize DHT sensor.
DHT dht(DHTPIN, DHTTYPE);
PubSubClient client(wifiClient);
int status = WL_IDLE_STATUS;
unsigned long lastSend;
void setup()
dht.begin();
delay(10);
InitWiFi();
client.setServer( thingsboardServer, 1883 );
lastSend = 0;
void loop()
if ( !client.connected() ) {
reconnect();
if ( millis() - lastSend > 1000 ) { // Update and send only after 1 seconds
getAndSendTemperatureAndHumidityData();
lastSend = millis();
client.loop();
void getAndSendTemperatureAndHumidityData()
Serial.println("Collecting temperature data.");
// Reading temperature or humidity takes about 250 milliseconds!
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
return;
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" *C ");
String temperature = String(t);
String humidity = String(h);
// Just debug messages
Serial.print( "Sending temperature and humidity : [" );
Serial.print( temperature ); Serial.print( "," );
Serial.print( humidity );
Serial.print( "] -> " );
// Prepare a JSON payload string
String payload = "{";
payload += "\"temperature\":"; payload += temperature; payload += ",";
payload += "\"humidity\":"; payload += humidity;
payload += "}";
// Send payload
char attributes[100];
payload.toCharArray( attributes, 100 );
client.publish( "v1/devices/me/telemetry", attributes );
Serial.println( attributes );
void InitWiFi()
Serial.println("Connecting to AP ...");
// attempt to connect to WiFi network
WiFi.begin(WIFI_AP, WIFI_PASSWORD);
Serial.print(".");
Serial.println("Connected to AP");
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
status = WiFi.status();
if ( status != WL_CONNECTED) {
Serial.print(".");
Serial.print("Connecting to ThingsBoard node ...");
// Attempt to connect (clientId, username, password)
if ( client.connect("ESP8266 Device", TOKEN, NULL) ) {
Serial.println( "[DONE]" );
} else {
Serial.print( "[FAILED] [ rc = " );
Serial.print( client.state() );
Serial.println( " : retrying in 5 seconds]" );
// Wait 5 seconds before retrying
delay( 5000 );
}My code which simply duplicates the 1 DHT into 2 and makes them DHT11 instead of DHT22 is:
#include "DHT.h"
#define WIFI_AP "Linksys_1"
//#define TOKEN "ESP8266_DEMO_TOKEN"
// DHT
#define DHTPIN1 D4
#define DHTPIN2 D5
#define DHTPIN3 D6
#define DHTTYPE DHT11
char MQTTServer[] = "192.168.0.200";
DHT dht1(DHTPIN1, DHTTYPE);
DHT dht2(DHTPIN2, DHTTYPE);
DHT dht3(DHTPIN3, DHTTYPE);
int value = 0;
void setup()
pinMode(DHTPIN1, INPUT_PULLUP);
pinMode(DHTPIN2, INPUT_PULLUP);
pinMode(DHTPIN3, INPUT_PULLUP);
dht1.begin();
dht2.begin();
dht3.begin();
delay(10);
InitWiFi();
client.setServer( MQTTServer, 1883 );
lastSend = 0;
void loop()
reconnect();
if ( millis() - lastSend > 60000 ) { // Update and send only after 60 seconds
client.loop();
++value;
float h1 = dht1.readHumidity();
float h2 = dht2.readHumidity();
float h3 = dht3.readHumidity();
float t1 = dht1.readTemperature();
float t2 = dht2.readTemperature();
float t3 = dht3.readTemperature();
if (isnan(h1) || isnan(t1)) {
Serial.println("Failed to read from DHT1 sensor!");
Serial.print("Humidity1: ");
Serial.print(h1);
Serial.print("Temperature1: ");
Serial.print(t1);
Serial.println(" *C ");
String temperature1 = String(t1);
String humidity1 = String(h1);
Serial.print( "Sending temperature1 and humidity1 : [" );
Serial.print( temperature1 ); Serial.print( "," );
Serial.print( humidity1 );
// Prepare a JSON payload string DHT1
String payload = "";
payload += "temperature="; payload += temperature1; payload += ",";
payload += "humidity="; payload += humidity1;
// Send payload
client.publish( "Safe1", attributes );
if (isnan(h2) || isnan(t2)) {
Serial.println("Failed to read from DHT2 sensor!");
Serial.print("Humidity2: ");
Serial.print(h2);
Serial.print("Temperature2: ");
Serial.print(t2);
String temperature2 = String(t2);
String humidity2 = String(h2);
Serial.print( "Sending temperature2 and humidity2 : [" );
Serial.print( temperature2 ); Serial.print( "," );
Serial.print( humidity2 );
// Prepare a JSON payload string DHT2
payload += "temperature="; payload += temperature2; payload += ",";
payload += "humidity="; payload += humidity2;
// Send payload
client.publish( "Safe2", attributes );
if (isnan(h3) || isnan(t3)) {
Serial.println("Failed to read from DHT3 sensor!");
Serial.print("Humidity3: ");
Serial.print(h3);
Serial.print("Temperature3: ");
Serial.print(t3);
String temperature3 = String(t3);
String humidity3 = String(h3);
Serial.print( "Sending temperature3 and humidity3 : [" );
Serial.print( temperature3 ); Serial.print( "," );
Serial.print( humidity3 );
// Prepare a JSON payload string DHT3
payload += "temperature="; payload += temperature3; payload += ",";
payload += "humidity="; payload += humidity3;
// Send payload
client.publish( "Safe3", attributes );
void InitWiFi()
WiFi.begin(WIFI_AP);
Serial.print(".");
void reconnect() {
Serial.print(".");
Serial.print("Connecting to MQTT server ...");
if ( client.connect("ESP8266 Device") ) {
} else {
delay( 5000 );
