extern "C" {
#include "user_interface.h"
typedef struct {
boolean var1 = false;
uint8_t var2 = 0;
uint8_t var3 = 0;
} rtcStore;
rtcStore RTCvals;And here's a line that works:
system_rtc_mem_write(64, &RTCvals, sizeof(RTCvals));This also works to store one variable starting at bucket 64:
system_rtc_mem_write(64, &RTCvals.var1, 4);However, the problem is storing an individual variable from RTCvals at any other bucket number, like 65 or 66:
if (!system_rtc_mem_write(65, &RTCvals.var2, 4)) Serial.println("FAILED!");The line above will print "FAILED!". I'm also pretty sure it used to work before, so I'm a bit baffled. Any ideas what's going on here?
Thanks!
