By jarnoldbrown
#74126 The subject title pretty much says it all. I'm hoping to use an ESP8266 as an AP, with 3 or 4 connected ESP8266 modules connected as STA. I'd like to send broadcast USP packets to all of them every 100mS or so. One byte of payload would probably suffice.
Interested in any pointers.
By rudy
#74129 Broadcast is not very reliable. Sending Unicast would be much better, but you would need to send once to each ESP.
This would be a good starting point. You would not need the reception part, just send duplicate the send.
https://github.com/esp8266/Arduino/blob ... amples.rst
By jarnoldbrown
#74130 OK. I will take a look at this tomorrow. Thanks.
My thinking was that if I send broadcast ever 100mS, say, then I can tolerate a few lost packets. The slave devices only need to control a few output pins, and I'm assuming that the packets are erro-checked.
