By FrankB
#74499 Hi,
I am currently running a wemos D1 board as a wireless sensor-node.
The node is streaming data via UDP to a server running InfluxDB.
Due to the fact, that UDP is, as expected, loosing packages every now and then I am looking for an alternative transfer method.
InfluxDB recommends HTTP as their preferred method, but I kind of have the feeling that I need something with a bit less overhead as I have to pump quite a bit of date through the network.
Another interface option to InfluxDB is telnet.
Now, finally my question: I have seen examples of using using the ESP8266 as a telnet server.
However, am I right to assume, that in my case, the ESP should be a client?
I am far from being a networking expert, so, any hints would be much appreciated.
Thx
Kind
