Timer1 + SoftAP + Webserver => WiFi hangs
Posted: Sun Mar 18, 2018 12:34 pm
I need to do data collection at fixed intervals. For this I need an ISR on Timer1. Using the "os timer" or the "loop" is not reliable enough for this. Both alternatives would avoid any WiFi hangs but don't collect the data properly.
This interrupt for itself seems to work very reliably. I've checked by toggling a pin and recording it on the oscilloscope. I trigger the interrupt every 1000 us for this test. The remaining jitter is down to +-3 us. This seems good enough for data collection. The interrupt function itself seems to be 100% reliable even when pages are served or the WiFi starts to hang.
I set up a SoftAP and serve a page via ESP8266WebServer. I serve a big page for testing and call "yield()" repeatedly inside the http handler. When the Timer1 interrupt is disabled, this also works very reliably. I've reloaded the page a thousand times without problems.
BUT
With all three Timer1 + SoftAP + Webserver enabled I get the following situation:
Case A: Interrupt is limited to 10 us.
Case B: Interrupt takes 600 us.
I have tried to find the answers to these questions but didn't find anything useful. A dozen people must have run into the same problems but I didn't find any.
BUT
- Everything is fine.
- When not serving pages everything seems fine.
- When serving pages it works a few reloads and then hangs.
- The ESP stops serving pages and also stops answering pings at that time.
- After a reset it works again until the page is loaded a few times.
- Is the SoftAP mode not compatible with interrupts?
- Is there a maximum time duration for ISR where they are safe? (10 us seems safe but is too short for me, 600 us is unstable.)
- Is there a maximum processing percentage reserved for interrupt routines? (E.g. 30%)
- Do I need to configure something so it stays stable?
