By terenceang
#76470 Hi,
I2C don't seems to work on Wemos D1 mini and BMP180 shield, running an i2c scanner sketch works if you search a range of address but it if you only search for 1(or 2) address it returns a NACK.
BMP180 is on 0x77. error code return was 2.
Been trying various different ways to get it to work without success. any help is appreciated.
Terence.
Sketch for testing.
Code: Select all#include <Wire.h>
void setup()
   //D1 - SCL
   //D2 - SDA
   Wire.begin();
   Serial.begin(9600);
   while (!Serial);             // Leonardo: wait for serial monitor
   Serial.print("\nI2C Scanner : ");
//0:success
//1 : data too long to fit in transmit buffer
//2 : received NACK on transmit of address
//3 : received NACK on transmit of data
//4 : other error
void loop()
   byte error, address;
   int nDevices;
   Serial.println("Scanning...");
   nDevices = 0;
   for (address = 0x75; address < 0x78; address++)
      Wire.beginTransmission(address);
      error = Wire.endTransmission();
      Serial.print("error = ");
      Serial.println(error);
      Wire.flush();
      if (error == 0)
         Serial.print("I2C device found at address 0x");
         if (address<16)
            Serial.print("0");
         Serial.print(address, HEX);
         Serial.println("  !");
         nDevices++;
      else if (error == 4)
         Serial.print("Unknown error at address 0x");
         if (address<16)
            Serial.print("0");
         Serial.println(address, HEX);
   if (nDevices == 0)
      Serial.println("No I2C devices found\n");
      Serial.println("done\n");
   delay(5000);           // wait 5 seconds for next scan
