By toni
#77596 Hi all,
I'm trying to adapt
https://bl.ocks.org/mbostock/4241134
with an index.html as:
Code: Select all<!DOCTYPE html>
<svg width="960" height="673" stroke="#fff" stroke-width="0.5"></svg>
<script src="https://d3js.org/d3.v4.min.js"></script>
<script src="https://d3js.org/d3-hsv.v0.1.min.js"></script>
<script src="https://d3js.org/d3-contour.v1.min.js"></script>
<script>
var svg = d3.select("svg"),
    width = +svg.attr("width"),
    height = +svg.attr("height");
var i0 = d3.interpolateHsvLong(d3.hsv(120, 1, 0.65), d3.hsv(60, 1, 0.90)),
    i1 = d3.interpolateHsvLong(d3.hsv(60, 1, 0.90), d3.hsv(0, 0, 0.95)),
    interpolateTerrain = function(t) { return t < 0.5 ? i0(t * 2) : i1((t - 0.5) * 2); },
    color = d3.scaleSequential(interpolateTerrain).domain([90, 190]);
d3.json("volcano.json", function(error, volcano) {
  if (error) throw error;
  svg.selectAll("path")
    .data(d3.contours()
        .size([volcano.width, volcano.height])
        .thresholds(d3.range(90, 195, 5))
      (volcano.values))
    .enter().append("path")
      .attr("d", d3.geoPath(d3.geoIdentity().scale(width / volcano.width)))
      .attr("fill", function(d) { return color(d.value); });
</script>
to show data acquired by esp8266 using ESP8266WebServer, but it not refresh new data so index.html cannot show nothing. I tried several approaches (like keepalive) with no results.
What I'm doing bad??
Code: Select all#include <ArduinoJson.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <FS.h>
const char* ssid = "YOURSSID";
const char* password = "YOURPASSWORD";
const char* htmlfile = "/index.html";
ESP8266WebServer server(80);
// Mux 1
int oneA = D6;
int oneB = D7;
int oneC = D5;
int oneD = D8;
// Read off Values from Here
int COM1 = A0;
// Mux 2
int twoA = D3;
int twoB = D4;
int twoC = D2;
int twoD = D1;
// Apply voltage from here
int COM2 = D0;
// since not all pins of each multiplexer are connected to rows/columns on the skin
// the following arrays indicates which pins are connected, to reflect the following:
int colPinRef [] = {
  0, 1, 2, 3, 4, 5, 6, 7
int rowPinRef [] = {
int metaMsk[16][4] = {
  { 0, 0, 0, 0 },
  { 1, 0, 0, 0 },
  { 0, 1, 0, 0 },
  { 1, 1, 0, 0 },
  { 0, 0, 1, 0 },
  { 1, 0, 1, 0 },
  { 0, 1, 1, 0 },
  { 1, 1, 1, 0 },
  { 0, 0, 0, 1 },
  { 1, 0, 0, 1 },
  { 0, 1, 0, 1 },
  { 1, 1, 0, 1 },
  { 0, 0, 1, 1 },
  { 1, 0, 1, 1 },
  { 0, 1, 1, 1 },
  { 1, 1, 1, 1 }
// We will read off values one row at a time, this array will store those values
int matrixSize = 1 * 8;
int matrixValues[8];
// The values of these variables will be used to select the pin from multiplexers 1 and 2
// See HEF4067B Datasheet for codes (function table)
int c0 = 0;
int c1 = 0;
int c2 = 0;
int c3 = 0;
int col = 0; // storeing the bin code
// Used to select the pin from multiplexers 3 and 4
int r0 = 0;
int r1 = 0;
int r2 = 0;
int r3 = 0;
int row = 0; // storeing the bin code
int rowCount; // just a count
int ciclos;
long tiempoInicial;
String output;
  // Columns = INPUT
  // Mux 1
  pinMode(oneA, OUTPUT); //A
  pinMode(oneB, OUTPUT); //B
  pinMode(oneC, OUTPUT); //C
  pinMode(oneD, OUTPUT); //D
  // Read values from here
  pinMode(COM1, INPUT);
  // ROWS = OUTPUT
  // Mux 2
  pinMode(twoA, OUTPUT); //A
  pinMode(twoB, OUTPUT); //B
  pinMode(twoC, OUTPUT); //C
  pinMode(twoD, OUTPUT); //D
  pinMode(COM2, OUTPUT);
  digitalWrite(COM2, HIGH);
  tiempoInicial = millis();
  ciclos = 0;
  SPIFFS.begin();
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.println(ssid);
  Serial.print("IP address: ");
  server.on("/", handleRoot);
  server.on("/volcano.json", volcano);
  server.on("/",HTTP_GET, volcano);
  server.onNotFound(handleNotFound);
  /*server.on("/index.html", HTTP_GET, []() {
    StaticJsonBuffer<1174> jsonBuffer;
    JsonObject& volcano = jsonBuffer.createObject();
    volcano["width"] = 8;
    volcano["height"] = 8;
    JsonArray& analogValues = volcano.createNestedArray("values");
    for (int rowCount = 0; rowCount < 8; rowCount++) {
      r0 = metaMsk[rowPinRef[rowCount]][0];
      r1 = metaMsk[rowPinRef[rowCount]][1];
      r2 = metaMsk[rowPinRef[rowCount]][2];
      r3 = metaMsk[rowPinRef[rowCount]][3];
      digitalWrite(twoA, r0); //send to Digital OUT 1
      digitalWrite(twoB, r1); //send to Digital OUT 2
      digitalWrite(twoC, r2); //send to Digital OUT 3
      digitalWrite(twoD, r3); //send to Digital OUT 4
      for (int colCount = 0; colCount < 8; colCount++) {
        c0 = metaMsk[colPinRef[colCount]][0];
        c1 = metaMsk[colPinRef[colCount]][1];
        c2 = metaMsk[colPinRef[colCount]][2];
        c3 = metaMsk[colPinRef[colCount]][3];
        digitalWrite(oneA, c0); //send to Digital OUT 1
        digitalWrite(oneB, c1); //send to Digital OUT 2
        digitalWrite(oneC, c2); //send to Digital OUT 3
        digitalWrite(oneD, c3); //send to Digital OUT 4
        int val = analogRead(COM1);
        matrixValues[colCount] = val;
        analogValues.add(val);
      }//end for
      delay(2);
    }//end for
    output = "";
    volcano.printTo(output);
    Serial.println("server.volc" + (output));
    server.send(200, "application/json", output);
  server.begin();
void loop () {
  WiFiClient(keepalive);
  WiFiClient client;
  server.handleClient();
void volcano() {
    }//end for
    delay(2);
  }//end for
  output = "";
  Serial.println("volcano" + (output));
  // client.println(output);
void handleRoot() {
  server.sendHeader("Location", "/index.html", true);  //Redirect to our html web page
  server.send(302, "text/plane", "");
void handleNotFound() {
  if (loadFromSpiffs(server.uri())) return;
  String message = "File Not Found\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET) ? "GET" : "POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i = 0; i < server.args(); i++) {
    message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
  server.send(404, "text/plain", message);
bool loadFromSpiffs(String path) {
  String dataType = "text/plain";
  if (path.endsWith("/")) path += "index.htm";
  if (path.endsWith(".src")) path = path.substring(0, path.lastIndexOf("."));
  else if (path.endsWith(".html")) dataType = "text/html";
  else if (path.endsWith(".htm")) dataType = "text/html";
  else if (path.endsWith(".css")) dataType = "text/css";
  else if (path.endsWith(".js")) dataType = "application/javascript";
  else if (path.endsWith(".png")) dataType = "image/png";
  else if (path.endsWith(".gif")) dataType = "image/gif";
  else if (path.endsWith(".jpg")) dataType = "image/jpeg";
  else if (path.endsWith(".ico")) dataType = "image/x-icon";
  else if (path.endsWith(".xml")) dataType = "text/xml";
  else if (path.endsWith(".pdf")) dataType = "application/pdf";
  else if (path.endsWith(".zip")) dataType = "application/zip";
  File dataFile = SPIFFS.open(path.c_str(), "r");
  if (server.hasArg("download")) dataType = "application/octet-stream";
  if (server.streamFile(dataFile, dataType) != dataFile.size()) {
  dataFile.close();
  return true;
PD: I used <ArduinoJson.h> as a first attempt to do it, but really it is not necessary. All files are attached below.
Thank you
Toni
