ESP8266 SPIFFS not saving correctly?
Posted: Sat Sep 29, 2018 9:47 pm
Hey all I am having some issues with the SPIFFS for this Wemos D1 mini ESP8266 controller.
This is my Arduino sketch:
And this is the console output:
As you can see, the first old values has all 0's which is incorrect. AmbientLight should be 25 at that point since readSPIFFS 1 has 25. So this should read:
saveToSPIFFS #1 is sending values 25, 77, 107, 250, 155 and false which then outputs correctly as:
But this time AmbientLight should still be 25 since it was sent false. It should have taken the old value (25) and placed it into the newer save.
Moving on to saveToSPIFFS #2 the values again are incorrect. The AmbientLight however is correct here. Instead of this output:
it should be gathering the 4 previous old values:
The json after this should not be this:
{"R":0,"G":0,"B":0,"L":0,"A":25}
It should be this:
{"R":250,"G":77,"B":107,"L":250,"A":25}
And lastly, the output of readSPIFFS 2:
Is incorrect. It should output:
Then after a reset it should have that and not the below for readSPIFFS 1:
So, where am I messing up here?
#include <FS.h>
#include <ArduinoJson.h>
struct RGBLA {
uint8_t R;
uint8_t G;
uint8_t B;
uint8_t L;
uint8_t A;
if (!SPIFFS.begin()) {
Serial.println("error while mounting filesystem!");
} else {
RGBLA returnedVars = readSPIFFS();
Serial.println("Starting...");
Serial.println("readSPIFFS 1");
Serial.print("R: ");
Serial.println(returnedVars.R);
Serial.print("G: ");
Serial.println(returnedVars.G);
Serial.print("B: ");
Serial.println(returnedVars.B);
Serial.print("L: ");
Serial.println(returnedVars.L);
Serial.print("AmbientLight: ");
Serial.println(returnedVars.A);
Serial.println("==================================");
returnedVars = saveToSPIFFS(25,77, 107, 250, 155, false);
Serial.println("saveToSPIFFS #1");
returnedVars = saveToSPIFFS(205,17, 68, 50, 15, true);
Serial.println("saveToSPIFFS #2");
Serial.println("readSPIFFS 2");
Serial.println("END!");
RGBLA saveToSPIFFS(uint8_t R, uint8_t G, uint8_t B, uint8_t L, uint8_t A, bool saveA) {
File configFile = SPIFFS.open("/config.json", "w+");
if (configFile.size() > 3072) {
Serial.println("Config file size is too large.");
} else {
Serial.print("Writing json to Config file...");
StaticJsonBuffer<200> jsonBuffer;
JsonObject& json = jsonBuffer.createObject();
//Get the old value and save it
Serial.println("Old Values?");
if (saveA) {
//Save Ambient Light data
json["R"] = returnedVars.R;
json["G"] = returnedVars.G;
json["B"] = returnedVars.B;
json["L"] = returnedVars.L;
json["A"] = A;
//Now save the new data
returnedVars.A = A;
} else {
//Save RGBL data
json["R"] = R;
json["G"] = G;
json["B"] = B;
json["L"] = L;
json["A"] = returnedVars.A;
returnedVars.R = R;
returnedVars.G = G;
returnedVars.B = B;
returnedVars.L = L;
json.printTo(configFile);
configFile.close();
//Read new saved values into struct
//returnedVars = readSPIFFS();
return returnedVars;
RGBLA readSPIFFS() {
bool exist = SPIFFS.exists("/config.json");
if (exist) {
Serial.println("YAY!");
} else {
Serial.println("Boo!");
File configFile = SPIFFS.open("/config.json", "r");
std::unique_ptr<char[]> buf(new char[configFile.size()]);
configFile.readBytes(buf.get(), configFile.size());
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
RGBLA returnedVars;
String debugLogData;
json.printTo(debugLogData);
Serial.println("===============");
Serial.println(debugLogData);
returnedVars.R = json["R"];
returnedVars.G = json["G"];
returnedVars.B = json["B"];
returnedVars.L = json["L"];
returnedVars.A = json["A"];
configFile.close();
Starting...
readSPIFFS 1
R: 0
G: 0
B: 0
L: 0
AmbientLight: 25
Writing json to Config file...YAY!
Old Values?
R: 0
G: 0
B: 0
L: 0
AmbientLight: 0
saveToSPIFFS #1
R: 25
G: 77
B: 107
L: 250
AmbientLight: 0
Old Values?
R: 0
G: 0
B: 0
L: 0
AmbientLight: 0
saveToSPIFFS #2
R: 0
G: 0
B: 0
L: 0
AmbientLight: 15
YAY!
{"R":0,"G":0,"B":0,"L":0,"A":15}
readSPIFFS 2
R: 0
G: 0
B: 0
L: 0
AmbientLight: 25
END!
Old Values?
R: 0
G: 0
B: 0
L: 0
AmbientLight: 25
R: 25
G: 77
B: 107
L: 250
AmbientLight: 0
R: 25
G: 77
B: 107
L: 250
AmbientLight: 25
R: 0
G: 0
B: 0
L: 0
AmbientLight: 25
R: 25
G: 77
B: 107
L: 250
AmbientLight: 25
It should be this:
R: 0
G: 0
B: 0
L: 0
AmbientLight: 25
R: 25
G: 77
B: 107
L: 250
AmbientLight: 25
R: 0
G: 0
B: 0
L: 0
AmbientLight: 25
