Won't Connect to Network
Posted: Tue Nov 20, 2018 4:11 am
I have been working through some examples, progressively adding layers. I started with the OTA update. After getting that to work, I added in SPIFFS/JSON. I then moved onto an MQTT example. This is were I ran into problems. The examples wouldn't work. I was only trying to do the simplest example and it wouldn't work. I eventually turned on serial debugging and figured out that I wasn't connecting to my wireless network. I hadn't changed anything related to my network (network SSID or password). I reset my router, just to check if that was an issue. I went back to the simplest WiFi example sketch and I can't get it to connect to my network. I even tried uploading everything to a brand new board with the same outcome. I have gone back to previous known working versions of sketches and still nothing works. I have checked the credentials and they are the same as my computer, which are both attached to my 2.4GHz AP.
I have absolutely no idea what to try next. I imagine the issue could have something to do with my router, but I have no idea where to look.
Any ideas would be better then where I'm at now.
Thanks,
Cory
Thanks,
Cory
