#include <WiFiUdp.h>
char ssid[] = "lockit"; // your network SSID (name)
char pass[] = "fifa2018"; // your network password
//Your UTC Time Zone Differance India +5:30
char HH = 5;
char MM = 30;
unsigned int localPort = 2390; // local port to listen for UDP packets
/* Don't hardwire the IP address or we won't get the benefits of the pool.
* Lookup the IP address for the host name instead */
//IPAddress timeServer(129, 6, 15, 28); // time.nist.gov NTP server
IPAddress timeServerIP; // time.nist.gov NTP server address
const char* ntpServerName = "time.nist.gov";
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
WiFiUDP udp;
// SETUP
void setup()
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, pass);
Serial.print(".");
Serial.println("");
Serial.println("Starting UDP");
udp.begin(localPort);
Serial.print("Local port: ");
Serial.println(udp.localPort());
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address)
Serial.println("sending NTP packet...");
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
udp.beginPacket(address, 123); //NTP requests are to port 123
udp.write(packetBuffer, NTP_PACKET_SIZE);
udp.endPacket();
// LOOP
void loop()
char hours, minutes, seconds;
//get a random server from the pool
WiFi.hostByName(ntpServerName, timeServerIP);
sendNTPpacket(timeServerIP); // send an NTP packet to a time server
// wait to see if a reply is available
delay(1000);
int cb = udp.parsePacket();
if (!cb) {
Serial.println("no packet yet");
else {
Serial.print("packet received, length=");
Serial.println(cb);
udp.read(packetBuffer, NTP_PACKET_SIZE);
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
unsigned long secsSince1900 = highWord << 16 | lowWord;
const unsigned long seventyYears = 2208988800UL;
unsigned long epoch = secsSince1900 - seventyYears;
minutes = ((epoch % 3600) / 60);
minutes = minutes + MM; //Add UTC Time Zon
hours = (epoch % 86400L) / 3600;
if(minutes > 59)
hours = hours + HH + 1; //Add UTC Time Zone
minutes = minutes - 60;
hours = hours + HH;
Serial.print("The UTC time is "); // UTC is the time at Greenwich Meridian (GMT)
Serial.print(hours,DEC); // print the hour (86400 equals secs per day)
Serial.print(':');
Serial.print(minutes,DEC);
delay(1000);
}and this is the response it is getting
no packet yet
packet received, length=48
The UTC time is 15:16sending NTP packet...
no packet yet
no packet yet
no packet yet
no packet yet
no packet yet
no packet yet
no packet yet
no packet yet
no packet yet
no packet yet
The UTC time is 15:17sending NTP packet...
no packet yet
no packet yet
no packet yet
no packet yet
no packet yet
no packet yet
no packet yet
no packet yet
sending NTP packet..the internet is working fine. I am unabketo understand the reason behind it. I tried changing the nodemcu board but still same trouble
