By dirtyelf
#80781 I have a server running on an 8266 that sends a page with some controls on it for various IO.
The first couple times I load up the page everything works.
After a few the AP mode will stop working. It stops broadcasting, and calls to begin return false.
Am I running into some sort of buffer I need to flush? Could it be that I am changing global vars in the handler function?
By DIRR70
#81385 Hello dirtyelf,
What you are trying to archive is the same as in the library example "WiFiaccesspoint":
Code: Select all/*
 * Copyright (c) 2015, Majenko Technologies
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without modification,
 * are permitted provided that the following conditions are met:
 * * Redistributions of source code must retain the above copyright notice, this
 *   list of conditions and the following disclaimer.
 * * Redistributions in binary form must reproduce the above copyright notice, this
 *   list of conditions and the following disclaimer in the documentation and/or
 *   other materials provided with the distribution.
 * * Neither the name of Majenko Technologies nor the names of its
 *   contributors may be used to endorse or promote products derived from
 *   this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
 * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Create a WiFi access point and provide a web server on it. */
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
/* Set these to your desired credentials. */
const char *ssid = "ESPap";
const char *password = "thereisnospoon";
ESP8266WebServer server(80);
/* Just a little test message.  Go to http://192.168.4.1 in a web browser
 * connected to this access point to see it.
void handleRoot() {
   server.send(200, "text/html", "<h1>You are connected</h1>");
   delay(1000);
   Serial.print("Configuring access point...");
   /* You can remove the password parameter if you want the AP to be open. */
   WiFi.softAP(ssid, password);
   Serial.print("AP IP address: ");
   Serial.println(myIP);
   server.on("/", handleRoot);
   server.begin();
   server.handleClient();
This example is working absolutely well and it won't stop or block or anything. So, I'm afraid there must be a little "Oops" in your code. Maybe you could post your code... ;)
