I am using ESP8266-07 with Arduino 1.8.5 IDE
The goal of my project:
I receive a web request from another ESP device (or my PC web browser for now)
I process the information (the temperature of a fridge or the voltage of 3 battery banks)
I display the information on a Waveshare 1.54 e-paper.
After uploading the code to the ESP I get:
Sketch uses 306508 bytes (29%) of program storage space. Maximum is 1023984 bytes.
Global variables use 38148 bytes (46%) of dynamic memory, leaving 43772 bytes for local variables. Maximum is 81920 bytes.When I boot the ESP the display updates itself
When I send a web request to the ESP, sometimes it works and sometimes it crashes showing:
Soft WDT reset
>>>stack>>>
ctx: cont
sp: 3ffffcd0 end: 3fffffc0 offset: 01b0I am not sure if I am doing the right thing by sending a web request as I don't need any feedback from the webpage, but I couln't think of another way.
Another mystery is if I add Serial.println("test") at the top of the loop, it behaves as expected but if I do the same at the bottom of the loop, it only shows up at the serial monitor when I send a web request.
Here is my code (only missing the image.h but that part works fine)
#include <NTPClient.h>
#include <WiFiUdp.h>
#include <ESP8266NetBIOS.h>
#include <GxEPD.h> // ---- https://github.com/ZinggJM/GxEPD
#include <GxGDEW0154Z04/GxGDEW0154Z04.cpp>
#include "images.h"
#include <Fonts/FreeMonoBold9pt7b.h>
#include <Fonts/FreeMonoBold12pt7b.h>
#include <Fonts/FreeMonoBold18pt7b.h>
#include <GxIO/GxIO_SPI/GxIO_SPI.cpp>
#include <GxIO/GxIO.cpp>
GxIO_Class io(SPI, /*CS=D16*/ 16, /*DC=D4*/ 4, /*RST=D5*/ 5);
GxEPD_Class ePaper(io, 5, 12 /*RST=D5*/ /*BUSY=D12*/);
const char* ssid = "myssid";
const char* password = "mypw";
String req,val1,val2,val3, valf;
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
String formattedDate;
String dayStamp;
String timeStamp;
String dtStampf = "0000-00-00 00:00";
String dtStampb = "0000-00-00 00:00";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
void updateDisplay();
void epaperUpdate();
delay(10);
updateDisplay();
NBNS.begin("FLOSTATION");
timeClient.begin();
timeClient.setTimeOffset(-14400);
// Connect to WiFi network
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
// Start the server
server.begin();
// Print the IP address
void updateDisplay() {
//Serial.println("Updating Display");
ePaper.init(115200); // enable diagnostic output on Serial
//Serial.println("Init Display");
ePaper.drawPaged(epaperUpdate);
void epaperUpdate() {
ePaper.eraseDisplay();
ePaper.setRotation(1);
ePaper.drawBitmap(gImage_boatdisp, 0, 0, 200, 200, GxEPD_RED);
ePaper.setTextColor(GxEPD_BLACK);
const GFXfont* f9 = &FreeMonoBold9pt7b;
const GFXfont* f12 = &FreeMonoBold12pt7b;
const GFXfont* f18 = &FreeMonoBold18pt7b;
ePaper.setFont(f18);
ePaper.setCursor(90, 50);
ePaper.print(valf);
ePaper.print("C");
ePaper.setFont(f9);
ePaper.setCursor(10, 80);
ePaper.println(dtStampf);
ePaper.setFont(f12);
ePaper.setCursor(80, 118);
ePaper.print("C ");
ePaper.print(val1);
ePaper.print("V");
ePaper.setCursor(80, 138);
ePaper.print("H ");
ePaper.print(val2);
ePaper.print("V");
ePaper.setCursor(80, 158);
ePaper.print("G ");
ePaper.print(val3);
ePaper.print("V");
ePaper.setFont(f9);
ePaper.setCursor(10, 182);
ePaper.println(dtStampb);
//----top of loop
if (!client) {
return;
while(!client.available()){
delay(1);
//generate request for battery with: http://FLOSTATION/batteryb100.00b200.00b300.00
//generate request for fridge with: http://FLOSTATION/fridge00
req = client.readStringUntil('\r');
//---------I don't need any response from that web page but if I don't include the folowing 6 lines,
// my code loops a bunch times.
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
client.flush();
client.stop();
//----expected input: 'GET /batteryb1xx.xxb2xx.xxb3xx.xx HTTP/1.1'
if(req.indexOf("battery") != -1){
val1 = req.substring(14, 19);
val2 = req.substring(21, 26);
val3 = req.substring(28, 33);
while(!timeClient.update()) {
timeClient.forceUpdate();
formattedDate = timeClient.getFormattedDate();
int splitT = formattedDate.indexOf("T");
dayStamp = formattedDate.substring(0, splitT);
timeStamp = formattedDate.substring(splitT+1, formattedDate.length()-4);
dtStampb = dayStamp + " " + timeStamp;
updateDisplay();
//----expected input: 'GET /fridgexx HTTP/1.1'
if(req.indexOf("fridge") != -1){
valf = req.substring(11, 13);
dtStampf = dayStamp + " " + timeStamp;
updateDisplay();
//----bottom of loop
