Here follows the complete compiling error:
C:\Users\Administrator\Documents\Arduino\teste_watsoniot\teste_watsoniot.ino: In function 'void setup()':
teste_watsoniot:65:14: error: 'Wifi' was not declared in this scope
if (strcmp(Wifi.SSID().c_str(), ssid) != 0) {
teste_watsoniot:73:59: error: 'Wifi' was not declared in this scope
Serial.print("Connected, IP address: "); Serial.println(Wifi.localIP()); ^
exit status 1 'Wifi' was not declared in this scope
Here follows the code:
#include <PubSubClient.h>
#include <SimpleTimer.h>
#include "DHT.h"
/* Wi-Fi Information */
const char* ssid = "xxx";
const char* password = "xxx";
/* Watson Configurations */
#define DEVICE_TYPE "xxx"
#define DEVICE_ID "xxx"
#define ORG "xxx"
#define TOKEN "xxx" // this authentication token given with API key
char server[] = ORG ".messaging.internetofthings.ibmcloud.com";
char topic[] = "iot-2/evt/status/fmt/json"; //"iot-2/type/xxx/id/xxx/evt/1-anl/fmt/json"; // customize type and ID
char authMethod[] = "use-token-auth";
//char authMeth[] = "xxx"; // here a API key
char token[] = TOKEN;
char clientID[] = "d:" ORG ":" DEVICE_TYPE ":" DEVICE_ID;
/* String to send data */
String Str1 = "hum";
String Str2 = "temp";
String Str3 = "ldrValue1";
String Str4 = "soilValue2";
/* Start Wi-Fi */
WiFiClientSecure wifiClient;
PubSubClient client(server, 1833, wifiClient);
/* TIMER */
SimpleTimer timer;
/* DHT22*/
#define DHTPIN D3
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
float hum = 0;
float temp = 0;
/* Soil Moister and LDR */
int sensorPin = A0; // analog input for both sensors
int enable1 = D1; // enable reading Sensor 1
int enable2 = D2; // enable reading Sensor 2
int ldrValue1 = 0;
int soilValue2 = 0;
void setup()
Serial.begin(115200); Serial.println();
Serial.print("Conectando na rede "); Serial.print(ssid);
WiFi.begin(ssid, password);
delay (500);
Serial.print (".");
Serial.println("");
timer.setInterval(1000L, getDhtData);
pinMode(enable1, OUTPUT);
pinMode(enable2, OUTPUT);
dht.begin();
/* Send to cloud */
void enviaDado(float dado1,float dado2, float dado3, float dado4){
String payload = "{\"d\":{\"" + Str1 + "\":";
payload += dado1;
payload += ", \"" + Str2 + "\":";
payload += dado2;
payload += ", \"" + Str3 + "\":";
payload += dado3;
payload += ", \"" + Str4 + "\":";
payload += dado4;
payload += "}}";
Serial.print("Sending payload: ");
Serial.println(payload);
//__ Envia o dado
if (client.publish(topic, (char*) payload.c_str())) {
Serial.println("Publish ok");
} else {
Serial.println("Publish failed");
void loop()
// Sensor DHT22
getDhtData();
// Sensor 1 LDR
digitalWrite(enable1, HIGH);
ldrValue1 = analogRead(sensorPin);
ldrValue1 = constrain(ldrValue1, 300, 850);
ldrValue1 = map(ldrValue1, 300, 850, 0, 1023);
Serial.print("Light intensity: ");
Serial.println(ldrValue1);
digitalWrite(enable1, LOW);
// Sensor 2 SOIL MOISTURE
digitalWrite(enable2, HIGH);
soilValue2 = analogRead(sensorPin);
soilValue2 = constrain(soilValue2, 300, 0);
soilValue2 = map(soilValue2, 300, 0, 0, 100);
Serial.print("Soil moisture: ");
Serial.println(soilValue2);
digitalWrite(enable2, LOW);
displayData();
delay(2000); // delay for getting DHT22 data
timer.run(); // Initiates SimpleTimer
/* Get DHT data */
void getDhtData(void)
float tempIni = temp;
float humIni = hum;
temp = dht.readTemperature();
hum = dht.readHumidity();
if (isnan(hum) || isnan(temp)) // Check if any reads failed and exit early (to try again).
temp = tempIni;
hum = humIni;
return;
/* display DHT data */
void displayData(void)
Serial.print(" Temperature: ");
Serial.print(temp);
Serial.print("oC Humidity: ");
Serial.print(hum);
Serial.println("%");
}Here is the source code: https://github.com/ibm-watson-iot/devic ... Secure.ino
