The ESP should NOT connect to WiFi for this purpose . (Battery)
Like this: Wake up by trigger -> check the lenght of the deepsleep
Explore... Chat... Share...
Pseudo code:
Get current date/time
Write to EEPROM
Go to deep sleep
Wake up
Get current date/time // Get it from where if no WiFi connection ?
Retrieve stored date/time from EEPROM
Subtract the two values: result is actual time spawnIt takes about 20-25 seconds for home assistant c[…]
