Elk: a restricted single-file JS engine for embedded systems
https://github.com/cesanta/elk
it can be used from within the arduino development environment ...
Explore... Chat... Share...
sfranzyshen wrote:(from the same people who brought you mongoose-os, mdash, mjs, and others ...)
Using library elk at version 0.0.16 in folder: /home/name/Arduino/libraries/elk
Sketch uses 280664 bytes (26%) of program storage space. Maximum is 1044464 bytes.
Global variables use 28552 bytes (34%) of dynamic memory, leaving 53368 bytes for local variables. Maximum is 81920 bytes.
Sketch uses 231185 bytes (17%) of program storage space. Maximum is 1310720 bytes.
Global variables use 16396 bytes (5%) of dynamic memory, leaving 311284 bytes for local variables. Maximum is 327680 bytes.
#include "elk.h" // Add Elk library
extern "C" void myDelay(int milli) { delay(milli); }
extern "C" void myWrite(int pin, int val) { digitalWrite(pin, val); }
extern "C" void myMode(int pin, int mode) { pinMode(pin, mode); }
struct js *js;
js = js_create(malloc(700), 700);
js_import(js, "f1", (uintptr_t) myDelay, "vi");
js_import(js, "f2", (uintptr_t) myWrite, "vii");
js_import(js, "f3", (uintptr_t) myMode, "vii");
js_eval(js, "f3(2, 1);", 0); // Set LED pin to OUTPUT mode ... tried f3(2, 2) also ...
js_eval(js, "f1(200); f2(2, 1); f1(200); f2(2, 0);", 0);
}// example of using the elk javascript engine innen Arduino Environment on esp
// Adafruit_NeoPixel strandtest.ino ported to elk javascript engine ...
#include <Adafruit_NeoPixel.h>
#include <elk.h>
#define ALLOC 2048
#define LED_PIN D2
#define LED_COUNT 8
#define DEBUG 1
struct js *js = js_create(malloc(ALLOC), ALLOC);
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
jsval_t v;
if(DEBUG) {
Serial.println("Starting ...");
js_import(js, "delay", (uintptr_t) Sys_delay, "vi");
js_import(js, "print", (uintptr_t) Sys_print, "vj");
js_import(js, "show", (uintptr_t) Neo_show, "v");
js_import(js, "clear", (uintptr_t) Neo_clear, "v");
js_import(js, "setPixelColor", (uintptr_t) Neo_setPixelColor, "viiii");
js_import(js, "WheelR", (uintptr_t) Neo_WheelR, "ii");
js_import(js, "WheelG", (uintptr_t) Neo_WheelG, "ii");
js_import(js, "WheelB", (uintptr_t) Neo_WheelB, "ii");
js_import(js, "jsinfo", (uintptr_t) js_info, "sm");
js_import(js, "numPixels", (uintptr_t) Neo_numPixels, "i");
v = js_eval(js, "let colorWipe = function(d, r, g, b) { let i = 0; while (i < numPixels()) { setPixelColor(i, r, g, b); show(); delay(d); i++; } delay(d * numPixels()); return i; };", 0);
if(DEBUG) {
Serial.print("let colorWipe result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "let theaterChase = function(d, r, g, bl) { let a = 0, b, c; while(a < 10) { b = 0; while(b < 3) { clear(); c = b; while(c < numPixels()) { setPixelColor(c, r, g, bl); c += 3; } show(); delay(d); b++; } a++; } return a; };", 0);
if(DEBUG) {
Serial.print("let theaterChase result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "let theaterChaseRainbow = function(wait) { let j = 0, q, i, p, r; while(j < 256) { q = 0; while(q < 3) { i = 0; while(i < numPixels()) { p = (i + j) % 255; r = i + q; setPixelColor(r, WheelR(p), WheelG(p), WheelB(p)); i = i + 3; } show(); delay(wait); i = 0; while(i < numPixels()) { r = i + q; setPixelColor(r, 0, 0, 0); i = i + 3; } q++; } j++; } return j; }; ", 0);
if(DEBUG) {
Serial.print("let theaterChaseRainbow result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "let rainbowCycle = function(wait) { let j = 0, i, p; while(j < 256 * 5) { i = 0; while(i < numPixels()) { p = ((i * 256 / numPixels()) + j) & 255; setPixelColor(i, WheelR(p), WheelG(p), WheelB(p)); i++; } show(); delay(wait); j++; } return j; };", 0);
if(DEBUG) {
Serial.print("let rainbowCycle result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "let rainbow = function(d) { let j = 0, i, p; while(j < 256) { i = 0; while(i < numPixels()) { p = (i + j) & 255; setPixelColor(i, WheelR(p), WheelG(p), WheelB(p)); i++; } show(); delay(d); j++; } return j; };", 0);
if(DEBUG) {
Serial.print("let rainbow result: "); Serial.println(js_str(js, v));
js_gc(js, v);
strip.begin();
strip.show();
strip.setBrightness(50);
if(DEBUG) {
v = js_eval(js, "print('VM Ready ...'); print(jsinfo(null));", 0);
Serial.print("jsinfo() result: "); Serial.println(js_str(js, v));
js_gc(js, v);
Serial.println("Setup Complete ...");
extern "C" void Neo_show() { strip.show(); }
extern "C" void Neo_clear() { strip.clear(); }
extern "C" void Neo_setPixelColor(uint16_t n, int r, int g, int b) { strip.setPixelColor(n, strip.Color(r, g, b)); }
extern "C" void Sys_delay(unsigned long milli) { delay(milli); }
extern "C" void Sys_print(jsval_t v) { Serial.println(js_str(js, v)); }
extern "C" int Neo_WheelR(int wheelpos) { return WheelR(wheelpos); }
extern "C" int Neo_WheelG(int wheelpos) { return WheelG(wheelpos); }
extern "C" int Neo_WheelB(int wheelpos) { return WheelB(wheelpos); }
extern "C" int Neo_numPixels(void) { return strip.numPixels(); }
int WheelR(int WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return (255 - WheelPos * 3);
if(WheelPos < 170) {
return (0);
WheelPos -= 170;
return (WheelPos * 3);
int WheelG(int WheelPos) {
if(WheelPos < 85) {
return (0);
WheelPos -= 85;
WheelPos -= 170;
int WheelB(int WheelPos) {
if(WheelPos < 85) {
WheelPos -= 85;
return (0);
jsval_t v;
if(DEBUG) {
Serial.println("Looping ...");
v = js_eval(js, "colorWipe(50, 255, 0, 0);", 0);
if(DEBUG) {
Serial.print("colorWipe() red result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "colorWipe(50, 0, 255, 0);", 0);
if(DEBUG) {
Serial.print("colorWipe() green result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "colorWipe(50, 0, 0, 255);", 0);
if(DEBUG) {
Serial.print("colorWipe() blue result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "theaterChase(50, 127, 127, 127);", 0);
if(DEBUG) {
Serial.print("theaterChase() white result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "theaterChase(50, 127, 0, 0);", 0);
if(DEBUG) {
Serial.print("theaterChase() red result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "theaterChase(50, 0, 0, 127);", 0);
if(DEBUG) {
Serial.print("theaterChase() blue result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "rainbow(30);", 0);
if(DEBUG) {
Serial.print("rainbow() result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "rainbowCycle(20);", 0);
if(DEBUG) {
Serial.print("rainbowCycle() result: "); Serial.println(js_str(js, v));
js_gc(js, v);
v = js_eval(js, "theaterChaseRainbow(50);", 0);
if(DEBUG) {
Serial.print("theaterChaseRainbow() result: "); Serial.println(js_str(js, v));
js_gc(js, v);
