I have one of those small all in one ESP8266 Relay modules and I'm struggling to get it connected using Gbridge.io. So far I've found one similar project on Instructables and have been toying around with his code but it seems the project is also incomplete and/or outdated.
The ESP8266 is showing up in my DHCP list so I know it has a solid connection and on the google home side it responds to my request to "turn on the fairy lights" (i want to control some lights with it) can anyone with knowledge of this look through this code I found and see if there is anything obvious?
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
/************************* WiFi Access Point *********************************/
#define WLAN_SSID "Your SSID name"
#define WLAN_PASS "Your SSID Password"
/************************* Gbridge Setup *********************************/
#define AIO_SERVER "mqtt.gbridge.io"
#define AIO_SERVERPORT 8883 // use 8883 for SSL
#define AIO_USERNAME "your gBridge username"
#define AIO_KEY "your gBridge password"
char outputState = 0;
char lastState = 0;
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClientSecure client;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
static const char *fingerprint PROGMEM = "9F B6 69 93 2B C3 E6 31 48 F7 BC 60 FB A8 79 FB DA FB 2A EA";
/****************************** Feeds ***************************************/
Adafruit_MQTT_Publish onoffset = Adafruit_MQTT_Publish(&mqtt, "gBridge/u0000/d1111/onoff/set"); //Replace by your feedname
Adafruit_MQTT_Subscribe onoffbutton = Adafruit_MQTT_Subscribe(&mqtt, "gBridge/u0000/d1111/onoff"); //Replace by your feedname
/*************************** Sketch Code ************************************/
// Bug workaround for Arduino 1.6.6, it seems to need a function declaration
// for some reason (only affects ESP8266, likely an arduino-builder bug).
void MQTT_connect();
delay(10);
Serial.println(F("Controle de lampe - Google Home"));
pinMode(LED_BUILTIN, OUTPUT); // Initialize the LED_BUILTIN pin as an output
digitalWrite(LED_BUILTIN, HIGH);
pinMode(0, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(0), handleInterrupt, FALLING);
// Connect to WiFi access point.
Serial.println(); Serial.println();
Serial.println(WLAN_SSID);
WiFi.begin(WLAN_SSID, WLAN_PASS);
Serial.print(".");
Serial.println("IP address: "); Serial.println(WiFi.localIP());
client.setFingerprint(fingerprint);
// Setup MQTT subscription for onoff feed.
mqtt.subscribe(&onoffbutton);
uint32_t x=0;
// Ensure the connection to the MQTT server is alive (this will make the first
// connection and automatically reconnect when disconnected). See the MQTT_connect
// function definition further below.
MQTT_connect();
// this is our 'wait for incoming subscription packets' busy subloop
// try to spend your time here
Adafruit_MQTT_Subscribe *subscription;
while ((subscription = mqtt.readSubscription(3000))) {
if (subscription == &onoffbutton) {
Serial.print(F("Got: "));
Serial.println((char *)onoffbutton.lastread);
if (strcmp((char *)onoffbutton.lastread, "1") == 0) {
digitalWrite(LED_BUILTIN, LOW);
outputState = 1;
if (strcmp((char *)onoffbutton.lastread, "0") == 0) {
outputState = 0;
// Now we can publish stuff!
if (outputState != lastState) {
lastState = outputState;
Serial.print(F("\nSending state val "));
Serial.print(outputState, BIN);
Serial.print("...");
if (! onoffset.publish(outputState)) {
Serial.println(F("Failed"));
} else {
Serial.println(F("OK!"));
// ping the server to keep the mqtt connection alive
// NOT required if you are publishing once every KEEPALIVE seconds
if(! mqtt.ping()) {
mqtt.disconnect();
ICACHE_RAM_ATTR void handleInterrupt() {
static unsigned long last_interrupt_time = 0;
unsigned long interrupt_time = millis();
if (interrupt_time - last_interrupt_time > 200)
if (outputState == 0) {
outputState = 1;
else {
outputState = 0;
last_interrupt_time = interrupt_time;
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
int8_t ret;
// Stop if already connected.
if (mqtt.connected()) {
return;
Serial.print("Connecting to MQTT... ");
uint8_t retries = 3;
while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
Serial.println(mqtt.connectErrorString(ret));
Serial.println("Retrying MQTT connection in 5 seconds...");
mqtt.disconnect();
delay(5000); // wait 5 seconds
retries--;
if (retries == 0) {
// basically die and wait for WDT to reset me
while (1);
Serial.println("MQTT Connected!");
}I have been through the code a few times and changed LED_Builtin to RelayPin, which I also defined on Pin 0 as these ESP modules control the relay via GPIO 0.
I feel as if this writeup I found on Instructables may be outdated or incomplete and would love to pursue this project but the help just really isn't out there (at least from my searches) when it comes to this board and the use of Gbridge over Google
