WiFi.forceSleepWake();
delay(100);
Serial.begin(1000000); pinMode( LED, OUTPUT );
pinMode( interruptPin, INPUT );
//attachInterrupt(digitalPinToInterrupt(interruptPin), handleInterrupt, CHANGE);
attachInterrupt(digitalPinToInterrupt(interruptPin), handleInterruptR, RISING);
attachInterrupt(digitalPinToInterrupt(interruptPin), handleInterruptF, FALLING);
Serial.println("\nStart");
ICACHE_RAM_ATTR void handleInterruptR() {
digitalWrite( LED, HIGH );
ICACHE_RAM_ATTR void handleInterruptF() {
digitalWrite( LED, LOW );
I have had problems with the ESP32. Getting multiple interrupts on the rising pulse that wasn't quick enough. It seems there was not hysteresis. I had to look at the input and a timer to see if it was a retriggered occurrence. I don't know if the ESP8266 is the same.
Using your idea I got it working reliably (at least when no other code is running).
const byte interruptPin = D3;
const byte errPin = D2;
WiFi.mode(WIFI_OFF);
delay(100);
pinMode( errPin, OUTPUT );
attachInterrupt(digitalPinToInterrupt(interruptPin), handleInterruptY, CHANGE);
//attachInterrupt(digitalPinToInterrupt(interruptPin), handleInterruptX, CHANGE);
ICACHE_RAM_ATTR void handleInterruptX() { // Not reliable
static bool lastPol = false;
lastPol = !lastPol;
digitalWrite( errPin, lastPol );
ICACHE_RAM_ATTR void handleInterruptY() { // Works fine
if (lastPol == digitalRead(interruptPin) ) {
return;
lastPol = !lastPol;
}The latency is close to 4uS, which I hope gives me plenty of time to store the timing.
My idea was to port the arduino pocsag receiver to ESP8266 (because I ran out of Mega2560).
