By dareko99
#86106 Hello
I have e problem with ESP8266 12E.
When i programming ESP with default software like WiFIESP8266 -> WiFiScan, program work normally, in monitor i have result schearch. But when I programming some software from APP RemoteMe, is programming normaly but don't work. Esp don't connect with server and in baud 74880 i see:
ctx: cont sp: 3ffffd40 end: 3fffffd0 offset:
01a0 >>>stack>>> 3ffffee0: 0000000c 3fffff50 3fffff5c 4020352e
or
ETS JAN 8 2013,RST CAUSE:2, BOOT MODE:(3,7).
In attach is automatic generated program form RemoteME. And schemat mu application.
Earliy I made similiar app with RemoteMe app and it work normally. I don't know where is a problem.
Code: Select all#define WIFI_NAME "2.4G-vnet-9776DC"
#define WIFI_PASSWORD "****************"
#define DEVICE_ID 2001
#define DEVICE_NAME "Smart_Home_1"
#define TOKEN "************"
#include <RemoteMe.h>
#include <RemoteMeSocketConnector.h>
RemoteMe& remoteMe = RemoteMe::getInstance(TOKEN, DEVICE_ID);
//*************** CODE FOR COMFORTABLE VARIABLE SET *********************
//*************** IMPLEMENT FUNCTIONS BELOW *********************
// method will be called when user message came
void onUserMessage(uint16_t senderDeviceId, uint16_t dataSize, uint8_t *data) {
   Serial.printf("got message sth size: %d\n",dataSize);
// this method will be called when sync message came to arduino You have to fill  returnData and returnDataSize
// as example now it reponse  one byte with 1 as value
void onUserSyncMessage(uint16_t senderDeviceId, uint16_t dataSize, uint8_t* data, uint16_t &returnDataSize, uint8_t *&returnData) {
   Serial.printf("got sync message sth size: %d\n",dataSize);
   returnDataSize = 1;
   returnData = (uint8_t*)malloc(returnDataSize);
   returnData[0]=1;
   WiFi.begin(WIFI_NAME, WIFI_PASSWORD);
      delay(100);
   remoteMe.setUserMessageListener(onUserMessage);
   remoteMe.setUserSyncMessageListener(onUserSyncMessage);
   remoteMe.setConnector(new RemoteMeSocketConnector());
   remoteMe.sendRegisterDeviceMessage(DEVICE_NAME);
   remoteMe.loop();
