Page 1 of 2
Cannot get ESP8266 POST to work.
PostPosted: Sat Apr 25, 2020 6:03 am
by AverageGuy
I am using the following code:
Code: Select all#include <ESP8266HTTPClient.h>
  Serial.begin(115200);                                  //Serial connection
  WiFi.begin("xxx", "rrrr");   //WiFi connection
  while (WiFi.status() != WL_CONNECTED) {  //Wait for the WiFI connection completion
    Serial.println("Waiting for connection");
 if(WiFi.status()== WL_CONNECTED){   //Check WiFi connection status
   HTTPClient http;    //Declare object of class HTTPClient
   http.begin("http://myserver.com/php2.php/");      //Specify request destination
   http.addHeader("Content-Type", "text/plain");  //Specify content-type header
   int httpCode = http.POST("{\"hello\":\"world\"}");   //Send the request
   String payload = http.getString();                  //Get the response payload
   Serial.println(httpCode);   //Print HTTP return code
   Serial.println(payload);    //Print request response payload
   http.end();  //Close connection
 }else{
    Serial.println("Error in WiFi connection");
  delay(30000);  //Send a request every 30 seconds
The php2.php code looks like:
Code: Select all<html>
<head>
<title>ESP8266 Post</title>
</head>
<body>
<?php
    $r=$_SERVER["REQUEST_METHOD"];
    echo "REQUEST METHOD $r<br>\n";
    $x=print_r($_REQUEST,true);
    $msg="NOT SET";
    if(isset($_REQUEST['msg'])) {
        $msg=  $_REQUEST['msg'];
    echo "REQUEST DUMP $x<br>\n";
    echo "MSG $msg<br>\n";
    $myvar = "Test Post";
    echo "TEST $myvar<br>\n";
<table>
<tr>
<td>
</td>
</tr>
</table>
</body>
</html>
The output in the /dev/ttyUSB0 serial console looks like
Code: Select all200
<html>
<head>
</head>
<body>
REQUEST METHOD POST<br>
REQUEST DUMP Array
<br>
MSG NOT SET<br>
TEST Test Post<br>
<table>
<tr>
<td>
</td>
</tr>
</table>
</body>
</html>
Any suggestions would be gladly received. I'll point you to the actual "myserver" in a pm if anyone want's to help.
Thanks,
Jim.
Re: Cannot get ESP8266 POST to work.
PostPosted: Sat Apr 25, 2020 11:35 am
by JurajA
I don't see any problem. You have a correct response. Or you want a php advice here?
PostPosted: Sat Apr 25, 2020 1:22 pm
by AverageGuy
JurajA wrote:I don't see any problem. You have a correct response. Or you want a php advice here?
Actually I didn't get the correct response. The retreived document didn't include any of the post data.
I'll take help anywhere I can get it. I have discovered that using the following makes it work:
Code: Select all   http.addHeader("Content-Type", "application/x-www-form-urlencoded");
   String httpRequestData = "msg=Hello World&api_key=tPmAT5Ab3j7F9&sensor=BME280&value1=24.25&value2=49.54&value3=1005.14";
   // Send HTTP POST request
   int httpCode = http.POST(httpRequestData);
Apparently it doesn't like Content-Type text-plain, nor does it like Content-Type application/json.
Output from first example:
Code: Select all200
<html>
<head>
</head>
<body>
REQUEST DUMP Array
    [msg] => Hello World
    [api_key] => tPmAT5Ab3j7F9
    [sensor] => BME280
    [value1] => 24.25
    [value2] => 49.54
    [value3] => 1005.14
<br>
MSG Hello World<br>
TEST Test Post<br>
<table>
<tr>
<td>
</td>
</tr>
</table>
</body>
</html>
I'm not sure why.
PostPosted: Sun Apr 26, 2020 12:57 am
by JurajA
so you were sending JSON from esp and expecting urlencoded in PHP. so the PHP was unable to pares it
