{TinkerCAD} ESP8266 does not communicate with Internet
PostPosted: Sat May 30, 2020 1:11 pm
by electrolux
My original post disappeared after I edited it so here I am typing everything again...
Situation
I do not have a real Arduino or ESP, I am using TinkerCAD and in that setup, I have an Arduino Uno R3 connected to an LCD, a temperature sensor, a button, and an ESP8266 to send temperature readings to the ThingSpeak IoT cloud.
Electrical Wiring
The Arduino's hardware serial is connected to the ESP8266 and communicates at 115200 baud. I am using an NMOSFET (2N7000) level shifter to convert the Arduino's 5V TX to the ESP's 3.3V RX.
Code: Select allArduino   ESP8266
GND         GND
                +3.3V from power supply, not the Arduino 3.3V output (current restrictions)
RX (1)      TX
TX (2)      RX via NMOS level shifter
                Enable  to 3.3V supply
                Reset    to 3.3V supply
Issue
The software initializes the ESP, sets it to Station Mode, Connects to the WiFi. The statuses are updated on the LCD so that I know when those things go amiss. Then the actual processing consists of:
1. Reading the temperature sensor
2. Opening a single TCP connection to the ThingSpeak cloud
3. Sending the GET request to update my ThingSpeak data channel
4. Closing the TCP connection to ThingSpeak
All steps except #3 work correctly. There basically I send the AT+CIPSEND=<length> and I am supposed to receive an ">" from the ESP but it never happens, it doesn't respond to the CIPSEND with anything really. After that, I submit the actual GET request but there I get no response from ESP either.
I also tried using CIPSEND without length and terminating the GET packet with CTRL+Z but no results either.
I also tried not reading the ESP response after CIPSEND=length and simply shooting the GET after a delay but nothing either, my packet never gets to the Internet.
I also tried using Webhook.site to see if my request was getting there (although my ThingSpeak data is correct) but nothing either.
So, what am I missing? I have examined and used a lot of code out there but nothing seems to work. Spent already two full days trying everything to no avail.
The Code
Here is the relevant part of my code. You may notice some code to setup LCD status indicators to give me immediate visual feedback (I don't have a secondary serial terminal).
Code: Select all// ------------------- ESP8266 -----------------
 *   Sets up the ESP8266, sets it to Station Mode and Connects WiFi AP
 *   REF: https://room-15.github.io/blog/2015/03/26/esp8266-at-command-reference/
void setupESP8266()
     lcdWiFiStatus(false);
    if(DEBUG){
      lcdBootStatus("E?");
    esp8266Module.flush();
    esp8266Module.println(F("AT+RST"));
    delay(7000);
    if (esp8266Module.find("OK"))
      if(DEBUG){
        PASSED('E');
      changeStationMode();       // put ESP8266 in Station Mode
      delay(5000);
      connectToWiFi();               // connect to WiFi network
    else
      if(DEBUG){
        FAIL('E');
 *   Sets ESP8266 to station mode
bool changeStationMode()
    esp8266Module.println(F("AT+CWMODE=1")); // 1=Station, 2=AP, 3=AP+Station
      if(DEBUG){
        PASSED('S');   // switched to Station Mode
      return true;
    else if(esp8266Module.find("NO CHANGE")){
      if(DEBUG){
        PASSED('S');
      return true;
    else
      if(DEBUG){
        FAIL('S');   // error switching to Station Mode
      return false;
 *  Connects ESP8266 to wifi access point
bool connectToWiFi()
  bool connected;
  if(DEBUG){
    lcdBootStatus("W?");
  String cmd = F("AT+CWJAP=\"");
  cmd += network;
  cmd += F("\",\"");
  cmd += password;
  cmd += F("\"");
  esp8266Module.println(cmd);
  delay(15000);
    if(DEBUG){
      PASSED('W');   // successful connection to WiFi AP
    connected = true;
  else
    if(DEBUG){
      FAIL('W');   // Could not connect to Access Point
    connected = false;
  lcdWiFiStatus(connected);
 *   Send data over WiFi to the Internet.
 *   Display the Transmit (arrow up) icon during sent.
 *   Blink the Receive icon (arrow down) while waiting for response.
 *   NOTE: THIS IS NOT WORKING PROPERLY - NO RESPONSES FROM ESP8266
String sendData(String command, const int timeout, boolean debug)
  String response = "";
  lcdSerialStatus(CHR_TX);      // LCD indicator for Tx
  esp8266Module.print(command); // send the request to the esp8266
  long int time = millis();
  const int BLINK_RELOAD = 100;
  int blink = BLINK_RELOAD;
  bool blinkOn = true;
  lcdSerialStatus(CHR_RX);
  while ( (time + timeout) > millis()) {
    while (esp8266Module.available()) {
      // output to the serial window
      char c = esp8266Module.read(); // read the next character.
      response += c;
    if (--blink == 0)
      if (blinkOn) {
        lcdSerialStatus(CHR_NONE);
      } else {
      blinkOn = !blinkOn;
  return response;
// ------------------- /ESP8266 -----------------
// -------------------  GENERAL -----------------
bool openTcpConnection(String host, int port)
  String openCmd = "AT+CIPSTART=\"TCP\",\"" + host + "\"," + port;
  esp8266Module.println(openCmd);
  delay(5000);        // Wait a little for the ESP to respond
  // response should have been CONNECT
  bool error = esp8266Module.find("Error");
  return !error;
// ------------------- /GENERAL -----------------
// ------------------- THINGSPEAK -----------------
 *   Open connection to Cloud over WiFi to ThingSpeak API
bool openCloudConnection()
  String openCmd = "AT+CIPSTART=\"TCP\",\"" + cfgIoT.Host
                + "\"," + cfgIoT.HttpPort;
  return !error;
 *   Close connection to Cloud service over WiFi
 *   http://www.pridopia.co.uk/pi-doc/ESP8266ATCommandsSet.pdf
void closeCloudConnection()
{   // for multiple connections AT+CIPCLOSE=<id>
   esp8266Module.println("AT+CIPCLOSE");
     delay(50);   // response CLOSED\r\nOK
    lcdCloudStatus(false);
int thingSpeakApiUpdateGet(int temperature)
  int retCode = 0;
  //openTcpConnection("46.4.105.116", 80);
  //sendRequest("GET /a3355acb-5c03-49b8-92a9-8b4610a12a54 HTTP/1.1","webhook.site");
  // send request
  String req;
  req = "GET /update?api_key=" + MY_CHANNEL_WRITE_API_KEY
       + "&field1=" + String(temperature, DEC)
       + " HTTP/1.1\r\nHost: " + "api.thingspeak.com" + "\r\n\r\n";
  String cipSend = "AT+CIPSEND=";
  //cipSend += 4;      // connection ID if CMUX=1 we aren't using that
  //cipSend += ", ";
  cipSend += String(req.length());
  cipSend += "\r\n";
  String rsp = sendData(cipSend, 1000, DEBUG); // should receive > but it never does!
  lcdPrintAt(0,0,rsp);
  rsp = sendData(req, 10000, DEBUG);
  return retCode;
Re: {TinkerCAD} ESP8266 does not communicate with Internet
PostPosted: Mon Jun 01, 2020 4:17 pm
by electrolux
So, is it then right to assume that my code is correct? or is there some undocumented quirk that is causing that code not to work?
