By radler63
#89051 Hello,
after selecting the installed esp8266 board in the board administrator, the java exception occurs
I would like to update because
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, ck, 26 MHz, 40MHz, QIO, 512K (no SPIFFS), v2 Prebuilt (MSS=536), Disabled, None, 115200"
exec: "/bin/xtensa-lx106-elf-g++": file does not exist
Ungültige Bibliothek E:\Standard\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.4.0\libraries\Servo in keine Header-Dateien (.h) in E:\Standard\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.4.0\libraries\Servo gefunden gefunden
Ungültige Bibliothek E:\Standard\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.4.0\libraries\SPISlave in keine Header-Dateien (.h) in E:\Standard\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.4.0\libraries\SPISlave gefunden gefunden
