By hevihoha
#89555 Hello, I wanted to make a program with an ESP8266 (WIFI) module, but every time on all the tutorials that I find, it doesn't work, I have an error when I compile:
"exit status 1
Compilation error for the Generic ESP8266 Module board "
While my card is plugged in, the drivers are recognized
I leave you one of the codes that does not work:
// the setup function runs once when you press reset or power the board
void setup () {
// initialize digital pin 13 as an output.
pinMode (2, OUTPUT);
// the loop function runs over and over again forever
void loop () {
digitalWrite (2, HIGH); // turn the LED on (HIGH is the voltage level)
delay (1000); // wait for a second
digitalWrite (2, LOW); // turn the LED off by making the voltage LOW
my favorite list of great porn site reviews https://dirtywonk.com/
