https://github.com/gilmaimon/ArduinoWebsockets
and although is compiled and downloaded correctly, when I try to access the WIFI server from the browser in the laptop, I can't... Any idea what is wrong? I use ESP8266-12E
Explore... Chat... Share...
Got Message:Got Message:1) In case I want the ESP8266 be accessible from more than 1 clients, can it work?
2)In case I want to access from an android phone, what should I do?
https://www.websocket.org/echo.htmlIt takes about 20-25 seconds for home assistant c[…]
