By Tertius21
#90499 I Connect to a saved Wifi. it works fine. Then i disconnect and try to reconnect with the same connect method as before, but reconnect is always connection result WL_IDLE_STATUS = 0
Why? What's wrong?
Here is my Code:
#include <WiFiManager.h>
WiFiManager wm;
  delay(100);
  Serial.println("");
  WiFi.mode(WIFI_STA); //  Station Mode
  Serial.print("try to connect to wifi ");
  Serial.println("SSID: " + WiFi.SSID());
  startWiFi(); // Connect
  delay(2000);
  wm.disconnect();
  Serial.println("Wifi Disconnected");
  Serial.println("");
  delay(2000);
  Serial.print("Try to RECONNECT to wifi ");
//                               startWiFi
   //for reference:
    //typedef enum {
    //    WL_NO_SHIELD = 255,   // for compatibility with WiFi Shield library
    //    WL_IDLE_STATUS = 0,
    //    WL_NO_SSID_AVAIL = 1,
    //    WL_SCAN_COMPLETED = 2,
    //    WL_CONNECTED = 3,
    //    WL_CONNECT_FAILED = 4,
    //    WL_CONNECTION_LOST = 5,
    //    WL_DISCONNECTED = 6
    //} wl_status_t;
void startWiFi() {
    Serial.print("Is WiFi Configured and saved: ");
    Serial.println((String)wm.getWiFiIsSaved() ? "YES" : "NO");
    if (!WiFi.isConnected()) {
        int conn_result = WiFi.waitForConnectResult(10000); // connect try it for 10 seconds
        Serial.print("conn_result: ");
        Serial.println(conn_result, DEC);
    if (WiFi.isConnected()) {
        Serial.println("Wifi is connected!");
    else {
        Serial.println("Wifi is NOT connected!");
    Serial.println("");
And here the results:
try to connect to wifi SSID: InProg1
Is WiFi Configured and saved: YES
SSID: InProg1
conn_result: 3
Wifi is connected!
Wifi Disconnected
Try to RECONNECT to wifi SSID: InProg1
SSID: InProg1
conn_result: 0
Wifi is not connected!
The conn_result 0 comes promptly not after 10 seconds.
