Problem with multiple http get request
PostPosted: Sat Jul 10, 2021 8:29 am
by WhiWhi
I have a problem with a Wemos D1 mini.
I try to make 2 Http Get Request to 2 different servers. I will update the temperature to an external website and to a local Domoticz server I have at home. The first http Request works but not the other. And I remove the first and just drive the other then work it so there is nothing wrong with the address itself. I would like help understanding what I do for the wrong or what it is too wrong on the code.
Maybe no good looking code but I'm a beginner.
And all SerialPrint is for trying to understand what is happening and not happening.
Code: Select all>
#include <Arduino.h
#include <ESP8266WiFiMulti.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include "SSD1306Wire.h"
ESP8266WiFiMulti WiFiMulti;
OneWire oneWire(2);
DallasTemperature sensors(&oneWire);
SSD1306Wire display(0x3C, 4, 5);
  WiFi.mode(WIFI_STA);
  WiFiMulti.addAP("ssid", "password");
  sensors.begin();
  Serial.begin(9600);
  Serial.println("Setup");
  display.init();
  display.flipScreenVertically();
  Serial.println("Loop");
  // wait for WiFi connection
  if ((WiFiMulti.run() == WL_CONNECTED)) {
    Serial.println("WIFI!");
    WiFiClient client;
    HTTPClient http;
    // Get temperature
    sensors.requestTemperatures();
    float temp = 0.0;
    float temp0 = sensors.getTempCByIndex(0);
    float temp1 = sensors.getTempCByIndex(1);
    if (temp0 < temp1 && temp0 > -56) {
      temp = temp0;
    } else if (temp1 < temp0 && temp1 > -56) {
      temp = temp1;
    } else {
      temp = temp0;
    String url = "http://www.temperatur.nu/rapportera.php?hash=****censur*****&t=";
    String url_d = "http://192.168.1.50:8080/json.htm?type=command&param=udevice&idx=1&nvalue=0&svalue=";
    Serial.println(temp);
    url.concat(temp);
    url_d.concat(temp);
    Serial.println(url);
    Serial.println(url_d);
    display.clear();
    display.setTextAlignment(TEXT_ALIGN_CENTER);
    display.setFont(ArialMT_Plain_24);
    display.drawString(64, 4, String(temp0, 2));
    display.drawString(64, 36, String(temp1, 2));
    display.display();
    if (temp > -56) {
      if (http.begin(client, url)) {  // HTTP
        int httpCode = http.GET();
        Serial.println("HTTP ?");
        // httpCode will be negative on error
        if (httpCode > 0) {
          Serial.println("HTTP 200");
          // Green
        } else {
          // Red
          Serial.printf("HTTP :( %s \n", http.errorToString(httpCode).c_str());
        http.end();
    delay(24000);
    if (temp > -56) {
      if (http.begin(client, url_d)) { // HTTP
      //if (http.begin(client, url_d)) { // HTTP
        Serial.println("HTTP GET dom");
        if (httpCode > 0) {
          String response = "HTTP ";
          response.concat(httpCode);
          response.concat(" dom");
          Serial.println(response);
          // Green
        } else {
          // Red
       // http.end();
    delay(35000);
