By Buddace
#92516 Hi,
I wrote simple function to manage WiFi connection of my ESP8266.
Im read data from INI and I would like set wWiFi according INI setup.
I have this proble, IF I join to ESP AP Network work only with static IP (automatic IP assignement don't work).
As ESP client if I try to disconnect from one network and connetct to another cannection fail (return value 7). Any idea to help ?
Code: Select allvoid WiFiConnect(const char* filename)
  IPAddress mask;
  if(ini_open (filename))
    NetworkChoice = ini_read ("NetworkChoice", "network","0");
    ClientSSID = ini_read ("network" + NetworkChoice , "ClientSSID","BuddaceCasa");
    ClientPassword = ini_read ("network" + NetworkChoice , "ClientPassword","25399750057853538077");
    ClientSSID0 = ini_read ("network0", "ClientSSID","BuddaceCasa");
    ClientPassword0 = ini_read ("network0", "ClientPassword","25399750057853538077");
    ClientSSID1 = ini_read ("network1", "ClientSSID","BuddaceCasa");
    ClientPassword1 = ini_read ("network1", "ClientPassword","25399750057853538077");
    ClientSSID2 = ini_read ("network2", "ClientSSID","BuddaceCasa");
    ClientPassword2 = ini_read ("network2", "ClientPassword","25399750057853538077");
    HostSSID = ini_read ("host", "HostSSID","CV19Archimede");
    HostPassword = ini_read ("host", "HostPassword","PlasticoCV19");
    HostIp = ini_read ("host", "HostIp","10.10.0.1");
    HostSubnetMask = ini_read ("host", "HostSubnetMask","255.0.0.0");
    ini_close();
    NetworkChoice = "0";
    ClientSSID = "BuddaceCasa";
    ClientPassword = "25399750057853538077";
    HostSSID = "CV19ArchimedeDef";
    HostPassword = "PlasticoCV19Def";
    HostIp = "10.0.0.1";
    HostSubnetMask = "255.0.0.0";
  Serial.println(NetworkChoice);
  Serial.println(ClientSSID);
  Serial.println(ClientPassword);
  Serial.println(HostSSID);
  Serial.println(HostPassword);
  Serial.println(HostIp);
  Serial.println(HostSubnetMask);
  // Connect to Wi-Fi
  //WiFi.mode(WIFI_AP_STA);
  WiFi.softAPdisconnect();
  WiFi.disconnect();
  delay(1000);
  Serial.println("Controllo disconnessione");
  Serial.println(WiFi.status());
  ip.fromString(HostIp.c_str());
  mask.fromString(HostSubnetMask.c_str());
  WiFi.softAP(HostSSID, HostPassword);
  WiFi.softAPConfig(ip, ip, mask);
  WiFi.begin(ClientSSID, ClientPassword);
  WiFi.hostname("CV19Archimede");
  WifiRetry = 0;
  while((WiFi.status() != WL_CONNECTED) && ( WifiRetry < WIFIRETRY))
    WifiRetry ++;
    if (WifiRetry > WIFIRETRY)
      WiFi.disconnect();
  Serial.println("stato corrente");
  Serial.println(WiFi.localIP().toString());
  ////Serial.println("Stato Wifi = " + String(WiFi.status()) + "fine stato" );
  MacAddress = WiFi.macAddress();
  WiFi.macAddress(mac);
  ClientIp = WiFi.localIP().toString();
  HostIp_Read = WiFi.softAPIP().toString();
  ip = WiFi.localIP();
  hostip = WiFi.softAPIP();
  WiFiEspNetwork();
