What is compiler directive to compile a block of code depending ESP8266 core version, for example:
#if (core version > 3.0.0)
compile this block
#else
compile this blockExplore... Chat... Share...
compile this block
#else
compile this blockIt takes about 20-25 seconds for home assistant c[…]
