OOPS.
It does some trafiic with an IP address in Argentina - 200.45.255.63 that is and resolves to ***.telecom.net.ar
Strange.
Can anyone confirm this? Module(s) is/ are programmed w/ the ESP-Arduino IDE and a fairly simple Webserver script - almost identical to the provided example.
I certainly will have a deeper look into this and if this might be a false positive.
markbee
EDIT: One other module does a 40 byte TCP connection to 32.53.255.63 (AT&T USA)
EDIT2: There seems to be a pattern:
56.46.255.63
40.46.255.63
are two more IPs only going off from ESP8266 and only if programmed with the Arduino IDE (as far as I can see). I did some cross check with NodeMCU and lua with a webserver and there seems to be no network traffic to the outside.
Please be aware that this might have any reason or any cause in my network. I'm further checking the network traffic and for now have disconnected all the ESP-modules to see if there is any traffic fitting to the addresses above.
