As the title already mentions, my question is, could be the Built-In LED Brightness controlled on D1 mini board?
If yes, how?
Thank you for the answers and suggestions,
Kind regards,
Viktor
Explore... Chat... Share...
pinMode(LED_BUILTIN, OUTPUT); // <==== LED_BUILTIN should be set automatically to GPIO2 when the correct board is selected
analogWrite(LED_BUILTIN, 127); // <==== change the second value [0...255] to set the brightness
}It takes about 20-25 seconds for home assistant c[…]
