By snakeninny
#95907 Hi!
I was testing OTA with NodeMCU and espClient was disconnected by ESPhttpUpdate.update as you can see this sketch:
Code: Select all#include "Arduino.h"
#include <ESP8266httpUpdate.h>
#include <PubSubClient.h>
#define ssid "SSID" // Change this
#define password "PASSWORD" // Change this
String upUrl = "https://bin.bemfa.com/b/3BcN2Q1NGY4NWFmNDI5NzZlZTNjMjY5M2U2OTJhNmJiNTk=light002.bin";
char serverName[] = "baidu.com";
WiFiClient espClient;
void onStart()
  Serial.println("onStart");
  Serial.printf("WiFiClient is %sconnected.\r\n", espClient.connected() ? "" : "NOT ");
void onEnd()
  Serial.println("onEnd");
void onProgress(int cur, int total)
  Serial.printf("onProgress at %d of %d bytes.\r\n", cur, total);
void onError(int err)
  Serial.printf("onError, err code = %d.\r\n", err);
void updateBin()
  WiFiClientSecure updateClient;
  updateClient.setInsecure();
  ESPhttpUpdate.onStart(onStart);
  ESPhttpUpdate.onEnd(onEnd);
  ESPhttpUpdate.onProgress(onProgress);
  ESPhttpUpdate.onError(onError);
  t_httpUpdate_return ret = ESPhttpUpdate.update(updateClient, upUrl);
  switch (ret)
  case HTTP_UPDATE_FAILED:
    Serial.println("HTTP_UPDATE_FAILED");
    break;
  case HTTP_UPDATE_NO_UPDATES:
    Serial.println("HTTP_UPDATE_NO_UPDATES");
    break;
  case HTTP_UPDATE_OK:
    Serial.println("HTTP_UPDATE_OK");
    break;
void setup()
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  if (espClient.connect(serverName, 443))
    if (espClient.connected())
      Serial.println("Connected to https://baidu.com.");
    updateBin();
void loop()
Code: Select all...........
onStart
WiFiClient is connected.
onProgress at 0 of 305120 bytes.
WiFiClient is NOT connected.
onProgress at 4096 of 305120 bytes.
Did I miss anything or this is normal?
How should I keep espClient CONNECTED while ESPhttpUpdate.update working?
Thanks,
Yinglu
