You should just need to modify the boards.txt file to change
Code: Select allgeneric.upload.maximum_size=524288
to
Code: Select allgeneric.upload.maximum_size=4194304
or however big your flash is.
In my case, I added a new board type for the ESPD-12 model (ESP-12 with 32mbit flash) which has the larger size. You could easily add a new board type for your large flash boards if you can get the flash wired up.
Here's my boards.txt file:
Code: Select allmenu.UploadSpeed=Upload Speed
menu.CpuFrequency=CPU Frequency
generic.name=Generic ESP8266 Module
generic.upload.tool=esptool
generic.upload.speed=115200
generic.upload.resetmethod=ck
generic.upload.wait_for_upload_port=true
generic.serial.disableDTR=true
generic.serial.disableRTS=true
generic.build.mcu=esp8266
generic.build.f_cpu=80000000L
generic.build.board=ESP8266_ESP01
generic.build.core=esp8266
generic.build.variant=generic
generic.menu.CpuFrequency.80=80 MHz
generic.menu.CpuFrequency.80.build.f_cpu=80000000L
generic.menu.CpuFrequency.160=160 MHz
generic.menu.CpuFrequency.160.build.f_cpu=160000000L
generic.menu.UploadSpeed.115200=115200
generic.menu.UploadSpeed.115200.upload.speed=115200
generic.menu.UploadSpeed.9600=9600
generic.menu.UploadSpeed.9600.upload.speed=9600
generic.menu.UploadSpeed.57600=57600
generic.menu.UploadSpeed.57600.upload.speed=57600
generic.menu.UploadSpeed.256000=256000
generic.menu.UploadSpeed.256000.upload.speed=256000
generic.menu.UploadSpeed.921600=921600
generic.menu.UploadSpeed.921600.upload.speed=921600
espd12.name=ESPD-12
espd12.upload.tool=esptool
espd12.upload.speed=115200
espd12.upload.resetmethod=ck
espd12.upload.maximum_size=4194304
espd12.upload.wait_for_upload_port=true
espd12.serial.disableDTR=true
espd12.serial.disableRTS=true
espd12.build.mcu=esp8266
espd12.build.f_cpu=80000000L
espd12.build.board=ESP8266_ESP01
espd12.build.core=esp8266
espd12.build.variant=espd12
espd12.menu.CpuFrequency.80=80 MHz
espd12.menu.CpuFrequency.80.build.f_cpu=80000000L
espd12.menu.CpuFrequency.160=160 MHz
espd12.menu.CpuFrequency.160.build.f_cpu=160000000L
espd12.menu.UploadSpeed.115200=115200
espd12.menu.UploadSpeed.115200.upload.speed=115200
espd12.menu.UploadSpeed.9600=9600
espd12.menu.UploadSpeed.9600.upload.speed=9600
espd12.menu.UploadSpeed.57600=57600
espd12.menu.UploadSpeed.57600.upload.speed=57600
espd12.menu.UploadSpeed.256000=256000
espd12.menu.UploadSpeed.256000.upload.speed=256000
espd12.menu.UploadSpeed.921600=921600
espd12.menu.UploadSpeed.921600.upload.speed=921600
wifio.name=Wifio
wifio.upload.tool=esptool
wifio.upload.speed=115200
wifio.upload.resetmethod=wifio
wifio.upload.maximum_size=524288
wifio.upload.wait_for_upload_port=true
wifio.build.mcu=esp8266
wifio.build.f_cpu=80000000L
wifio.build.board=ESP8266_WIFIO
wifio.build.core=esp8266
wifio.build.variant=wifio
wifio.menu.CpuFrequency.80=80MHz
wifio.menu.CpuFrequency.80.build.f_cpu=80000000L
wifio.menu.CpuFrequency.160=160MHz
wifio.menu.CpuFrequency.160.build.f_cpu=160000000L
