Page 1 of 2
Overclocking
PostPosted: Mon Apr 13, 2015 3:42 pm
by andrew melvin
Using the latest IDE... compiling and running at 160Mhz works... question is are there any caveats....
Warnings... etc...
Re: Overclocking
PostPosted: Fri Apr 17, 2015 6:47 am
by andrew melvin
Maybe I should rephrase my question.
Is it safe to run the ESP8266 at 160Mhz?
Re: Overclocking
PostPosted: Fri Apr 17, 2015 10:39 am
by raz123
Yes. This has been discussed in the past. Try searching.
Re: Overclocking
PostPosted: Sun Apr 19, 2015 5:23 pm
by Ben Baron
160MHz is a supported clock speed, it's not overclocking. It will just use more power than 80MHz, so no reason to use it unless you need the power for faster transfer speed or more calculations or whatever.
