ESP8266 controlling Heat Pump via IR
PostPosted: Mon Jun 22, 2015 3:11 am
by OliverNZ
Hi,
Has anyone tried to control a HeatPump via an IR LED from a ESP?
Originally I was planning on doing this with an Arduino but since switched to ESPs. The project I was using was this:
https://github.com/ToniA/arduino-heatpumpir
Anyone tried this before?
Cheers Oliver
Re: ESP8266 controlling Heat Pump via IR
PostPosted: Mon Jun 22, 2015 3:20 am
by OliverNZ
I had some issues with compiling so I guess there's work needed. Trawling through the code I can see this PWM stuff
https://github.com/ToniA/arduino-heatpu ... Sender.cpp
Needs to be adjusted to the ESP I guess. But no comments and it definitely reaches the limits of what code I can read/understand. I get what it's sort of doing but wouldn't even know where to start on the ESP.
Oliver
PostPosted: Fri Jan 22, 2016 5:59 am
by opeRaptor
Have you found a solution to this?
I am using a Japanese AC unit.
