By albal
#22561 Hi,
Just compiled blink to check my tool chain works. Binary sketch size: 197,420 bytes (used 38% of a 524,288 byte maximum) (10.93 secs)
Is something wrong here? Seems to be using a huge amount of memory. Probably not a big problem for me as over 300K free is fine for me.
Thanks,
Al
By brutzler
#22588 Hi thats normal.
Same values on my system.
"Der Sketch verwendet 197.420 Bytes (37%) des Programmspeicherplatzes. Das Maximum sind 524.288 Bytes."
Only funny, thats its only 37%
10 sec should only be for the first time, you started the IDE.
As I know, there is the whole "ESP-System" (~200k) implemented on compiling
