With the rapid pace of version updates across the used softwares, it will almost certainly be obsolete immediately.
It -is- entertaining enough to at least mention.
Everything is locally hosted. Cloud services have their place, but my preference is a setup that is capable of operating in remote locations without requiring internet access to function.
In addition to the esp8266, a local router and local server like an old laptop, BeagleBone or Raspberry Pi to run Mosquitto and openHAB are required.
Steps:
Find a system to act as the server. I had an old BeagleBone Black collecting dust.
In case you do too, the newest beaglebone OS is Debian instead of Angstrom. I like having apt-get on the beagle. It almost acts like a Raspberry Pi now
Download JAVA from the Oracle site. Sign up if you need to. Don't be tempted to install java from the Debian repo's. OpenHAB is dog slow with the Debian repo java version. Trust me on this one...
Mosquitto MQTT broker runs fine from the Debian repo's. There are some good blogs out there on initial setup and hello world examples with the pub/sub concepts and architecture of Mosquitto. Well worth spending an evening with.
The openHAB 1.7.1 demo worked out of the box for me. The UI alone is worth the learning curve price of admission.
The esp8266 code I am running. Obviously I like hardcoding IP addresses.
There may be a line or two of code that comes in handy if you decide to go down a similar rabbit hole.
For my 1.6.4 version of ESP8266/ARDUINO, I lifted just the PubSubClient library out of igrr's github repository and commented out:
//boolean publish_P(char *, uint8_t PROGMEM *, unsigned int, boolean);
in the PubSubClient.h file and the associated routine in the .cpp file.
mqtt_openHAB_2
Example program for esp8266-12 on the yellow carrier board.
Used to interact over local intranet with a mosquitto server and openHAB running on a seperate computer.
Ver. 2 Changed mqtt messaging structure to support multiple esp boards addressed by openHAB at different IP addresses
Copyright (c) 2015 R. Wynn. All rights reserved.
This is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This software is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include <PubSubClient.h>
const char* ssid = "yourssid";
const char* password = "yourpassword";
byte mqttServer[] = { 192, 168, 1, 114 };//Hardcode of mosquitto server IP on local intranet connected computer.
byte IP[] = { 192, 168, 1, 111 };//Hardcode for this esp8266 node
byte Netmask[] = { 255, 255, 255, 0 };//Local router info
byte Gateway[] = { 192, 168, 1, 1 }; //Local router info
WiFiClient wifiClient;
PubSubClient mqttClient(mqttServer, 1883, mqttCallback, wifiClient);
long millis_now; // For non-blocking delay
long millis_prev; // For non-blocking delay
long LEDredValue = 0;
long LEDgreenValue = 0;
long LEDblueValue = 0;
long lightsensor = 0;
// Callback payload parsing inspired from code found at http://blue-pc.net
void mqttCallback(char* topic, byte* payload, unsigned int length) {
int i = 0;
char message_buff[100];
for(i=0; i<length; i++) {
message_buff[i] = payload[i];
message_buff[i] = '\0';
String msgString = String(message_buff);
//Serial.print("topic: ");
//Serial.println(String(topic));
//Serial.print("payload: ");
//Serial.println(String(msgString));
if (String(topic) == "openHAB/esp_111/RED") {
LEDredValue = round(msgString.toInt() * 10.2);
//Serial.print("Red: ");
//Serial.println(LEDredValue);
analogWrite(15,LEDredValue);
if (String(topic) == "openHAB/esp_111/GREEN") {
LEDgreenValue = round(msgString.toInt() * 10.2);
//Serial.print("Green: ");
//Serial.println(LEDgreenValue);
analogWrite(12,LEDgreenValue);
if (String(topic) == "openHAB/esp_111/BLUE") {
LEDblueValue = round(msgString.toInt() * 10.2);
//Serial.print("Blue: ");
//Serial.println(LEDblueValue);
analogWrite(13,LEDblueValue);
if (String(topic) == "openHAB/esp_111/led1") {
if (msgString == "ON") digitalWrite( 2, 0 ); //red leds are inverted output
else digitalWrite( 2, 1 );
if (String(topic) == "openHAB/esp_111/led2") {
if (msgString == "ON") digitalWrite( 0, 0 ); //red leds are inverted output
else digitalWrite( 0, 1 );
if (String(topic) == "openHAB/esp_111/led3") {
if (msgString == "ON") digitalWrite( 4, 0 ); //red leds are inverted output
else digitalWrite( 4, 1 );
if (String(topic) == "openHAB/esp_111/led4") {
if (msgString == "ON") digitalWrite( 5, 0 ); //red leds are inverted output
else digitalWrite( 5, 1 );
if (String(topic) == "openHAB/esp_111/led5") {
if (msgString == "ON") digitalWrite( 14, 0 ); //red leds are inverted output
else digitalWrite( 14, 1 );
if (String(topic) == "openHAB/esp_111/led6") {
if (msgString == "ON") digitalWrite( 16, 0 ); //red leds are inverted output
else digitalWrite( 16, 1 );
void setup()
// ESP-12 yellow carrier board GPIO assignments
pinMode(A0, INPUT); // analog light sensor input
pinMode(2, OUTPUT); // 00000X discrete red led position
pinMode(0, OUTPUT); // 0000X0 discrete red led position
pinMode(4, OUTPUT); // 000X00 discrete red led position
pinMode(5, OUTPUT); // 00X000 discrete red led position
pinMode(14,OUTPUT); // 0X0000 discrete red led position
pinMode(16,OUTPUT); // X00000 discrete red led position
pinMode(15,OUTPUT); // RGB led red
pinMode(12,OUTPUT); // RGB led green
pinMode(13,OUTPUT); // RGB led blue
// initialize GPIO 'inverted' led outputs to off
digitalWrite(2, 1); // red leds are inverted output
digitalWrite(0, 1); // red leds are inverted output
digitalWrite(4, 1); // red leds are inverted output
digitalWrite(5, 1); // red leds are inverted output
digitalWrite(14,1); // red leds are inverted output
digitalWrite(16,1); // red leds are inverted output
digitalWrite(15,0); // RGB led red not inverted
digitalWrite(12,0); // RGB led green not inverted
digitalWrite(13,0); // RGB led blue not inverted
delay(10);
Serial.print("WiFi connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
WiFi.config(IPAddress(IP[0],IP[1],IP[2],IP[3] ), IPAddress(Gateway[0],Gateway[1],Gateway[2],Gateway[3] ) , IPAddress(Netmask[0],Netmask[1],Netmask[2],Netmask[3] ));
WiFi.mode(WIFI_STA);
Serial.print(".");
Serial.println("");
Serial.println("ESP8266 IP address: ");
yield(); // Will this help get a mqtt connection the first time? It won't hurt. It ...might... help.
mqttClient.connect("esp8266Client_111");
// Will implement retry in loop() if not connected here
if (mqttClient.connect("esp8266Client_111")) {
mqttClient.publish("esp_111","Hello from esp8266 mosquitto client");
mqttClient.subscribe("openHAB/esp_111/#");
Serial.println("Connected to mosquitto mqtt server.");
else {
Serial.println("Failed to connected with mosquitto mqtt server.");
void loop()
mqttClient.loop(); //Must call this function to let mqtt subscribe callbacks work
millis_now = millis();
if (millis_now > (millis_prev + 10000)){ //1000 = 1sec Non-blocking delay
static int counter = 0;
String payloadxmit = "{\"micros\":";
payloadxmit += micros();
payloadxmit += ",\"counter\":";
//payloadxmit += (String) counter;
payloadxmit += counter;
payloadxmit += "}";
if (mqttClient.connected()){
Serial.print("Sending payload: ");
Serial.println(payloadxmit);
if (mqttClient.publish("esp_111", (char*) payloadxmit.c_str())) {
Serial.println("mqtt publish ok");
else {
Serial.println("mqtt publish failed");
lightsensor = analogRead(A0);
char sensor[8];
itoa(lightsensor,sensor,10); // integer to string, base 10 (decimal)
if (mqttClient.publish("esp_111/sensor", sensor)) {
else {
else{
Serial.println("Attempting to reestablish mosquitto mqtt connection");
mqttClient.publish("esp_111","Hello again from esp8266 mosquitto client");
++counter;
millis_prev = millis_now;
}Proof-of-life screenshot from openHAB:
This assemblage of stuff has been running surprisingly stable for a few days. Certainly more of a testament to the underlying software than my app code on top!
The addition of mesh networking the esp8266's into this sort of setup will be something like a swiss army knife of home automation.
