Which one is the proper library-folder?
PostPosted: Thu Aug 20, 2015 1:11 pm
by brutzler
HI,
still somehow confused about the proper folder for libs.
After installation of IDE and ESP-package, there are two library-folders.
- The folder in the Arduino IDE: C:\Arduino\libraries
- The folder in the ESP-package: C:\Users\brutzler\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-1044-g170995a\libraries
Comparing theese two, I see that e.g. SD-lib is placed in both???
How is this managed by the compiler?
Re: Which one is the proper library-folder?
PostPosted: Fri Aug 21, 2015 2:14 am
by schufti
enable the compiler output option under settings and you will see that automagically the correct path is choosen. This is for libraries preinstalled with the "boards".
There should be another library folder in your sketchbook folder where the user installed libraries go.
