ESP have an ip but don't communicate with any thing
PostPosted: Thu Aug 27, 2015 9:47 am
by sebastien delporte
Hi,
I have a problem, i execute this simple code - send an http request :
//Router 1 - Livebox
const char* ssid     = "Livebox-9e38";
const char* password = "xxxxxxxxxxx";
//Router 2 - Android phone
//const char* ssid     = "DARKSIDE";
//const char* password = "xxxxxxxxx";
// server address:
char server[] = "www.arduino.cc";
//IPAddress server(64,131,82,241);
WiFiClient client;
unsigned long lastConnectionTime = 0;            // last time you connected to the server, in milliseconds
const unsigned long postingInterval = 10L * 1000L; // delay between updates, in milliseconds
  delay(10);
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.println("");
void httpRequest() {
  // close any connection before send a new request.
  // This will free the socket on the WiFi shield
  client.stop();
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    Serial.println("connecting...");
    // send the HTTP PUT request:
    client.println("GET /latest.txt HTTP/1.1");
    client.println("Host: www.arduino.cc");
    client.println("User-Agent: ArduinoWiFi/1.1");
    client.println("Connection: close");
    client.println();
    // note the time that the connection was made:
    lastConnectionTime = millis();
  } else {
    // if you couldn't make a connection:
  // if there's incoming data from the net connection.
  // send it out the serial port.  This is for debugging
  // purposes only:
  while (client.available()) {
    char c = client.read();
    Serial.write(c);
  // if ten seconds have passed since your last connection,
  // then connect again and send data:
  if (millis() - lastConnectionTime > postingInterval) {
    httpRequest();
When I am on the router 2 (a simple hotspot router on a android phone) the code works.
When I am on the router 1 (a livebox supply by my internet provider), i have an IP address, i can see the ESP in the router (it's a web interface) but i can't get any result form the request (and i can't ping the module). The router don't route anything.
Of course the router have access to internet and from a computer connect to the router in wifi with the Curl command, the request work.
Have you some idea for me ?
Regards,
