I'm trying to do an http get to a remote http server, which returns simply a one word response "cooling" "off" or "heating". When I test this url from my web browser, it returns accurate info, immediately, every time.
Now I'm trying to write code from my Spark Thing esp82666.
Boot
Connect to wifi
http request
read external sensor
compare sensor value to hvac state.
send IR code if needed
deep sleep with WAKE_RF_DISABLED
My problem is this. The initial time it runs after power-on, it runs perfectly. From there on out, it appears to randomly return either null string, or the proper http word response.
Below is the code, don't make fun
#include <Phant.h>
const char* ssid = "wifi-ssid";
const char* password = "wifi-pass";
const char* host = "sync-nest.appspot.com";
static const uint8_t powerCodeTable[] = {0,0,0,1, 0,0,0,0,
1,0,1,0, 1,1,1,1,
1,0,0,0, 1,0,0,0,
0,1,1,1, 0,1,1,1} ;
const int irLED = 4 ;
static const int sensorReads = 5 ;
static const int sensorPause = 500 ;
static const int sensorThreshold = 350 ;
static const int wifiConnectRetries = 20 ;
static const int phantConnectRetries = 5 ;
static const int wifiClientConnectRetries = 5 ;
// Phant Keys //
const char PhantHost[] = "data.sparkfun.com";
const char PublicKey[] = "<public key>";
const char PrivateKey[] = "<private key>";
void pulseLED(uint16_t pulseTime) {
uint32_t end = micros() + pulseTime ;
uint32_t now ;
do {
now = micros() ;
digitalWrite(irLED, HIGH) ;
delayMicroseconds(13) ;
digitalWrite(irLED, LOW) ;
} while (now < end) ;
void powerAC () {
// Header
Serial.println("Sending Power IR Code") ;
pulseLED(9159) ;
delayMicroseconds(4455) ;
// commands
uint8_t i ;
for (i=0; i < 32 ; i++) {
if (powerCodeTable[i] == 1) {
pulseLED(639) ;
delayMicroseconds(1615) ;
} else {
pulseLED(639) ;
delayMicroseconds(486) ;
// Footer
pulseLED(637) ;
int postToPhant(int sensorValue)
// Declare an object from the Phant library - phant
Phant phant(PhantHost, PublicKey, PrivateKey);
// Do a little work to get a unique-ish name. Append the
// last two bytes of the MAC (HEX'd) to "Thing-":
uint8_t mac[WL_MAC_ADDR_LENGTH];
WiFi.macAddress(mac);
String macID = String(mac[WL_MAC_ADDR_LENGTH - 2], HEX) +
String(mac[WL_MAC_ADDR_LENGTH - 1], HEX);
macID.toUpperCase();
String postedID = "Thing-" + macID;
// Add the four field/value pairs defined by our stream:
phant.add("id", postedID);
phant.add("vibration", sensorValue);
// Now connect to data.sparkfun.com, and post our data:
WiFiClient phantclient;
const int httpPort = 80;
int connectTries = 0 ;
while (!phantclient.connect(PhantHost, httpPort))
delay(100) ;
if (connectTries++ > phantConnectRetries) {
// If we fail to connect, return 0.
return 0;
// If we successfully connected, print our Phant post:
phantclient.print(phant.post());
delay(5000) ;
while(phantclient.available()){
String line = phantclient.readStringUntil('\r');
//Serial.print(line); // Trying to avoid using serial
phantclient.stop() ;
return 1; // Return success
boolean acRunning() {
int sensorTotal = 0 ;
for (int i = 0 ; i < sensorReads ; i++) {
sensorTotal += analogRead(A0) ;
delay(sensorPause) ;
int sensorAverage = (int) sensorTotal / sensorReads ;
Serial.print("Sensor Average: ") ;
Serial.println(sensorAverage) ;
// post to phant
//Serial.println(postToPhant(sensorAverage)) ;
if (sensorAverage > sensorThreshold) {
Serial.println("AC is Running") ;
return true ;
} else {
Serial.println("AC is Off") ;
return false ;
delay(5000);
pinMode(irLED, OUTPUT) ;
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.print(WiFi.status()) ;
if (connectTries++ >= wifiConnectRetries) {
Serial.print("Wifi Connection tries > ") ;
Serial.print(wifiConnectRetries) ;
Serial.println(", restarting") ;
ESP.restart() ;
Serial.println("");
Serial.print("IP address: ");
Serial.print("Connecting to: ");
Serial.println(host);
WiFiClient client;
connectTries = 0 ;
while (!client.connect(host, httpPort)) {
delay(100) ;
if (connectTries++ > wifiClientConnectRetries) {
Serial.print("Wifi Client Connection tries > ") ;
Serial.print(wifiClientConnectRetries) ;
ESP.restart() ;
// We now create a URI for the request
String url = "/nest-thermostat-status.php";
Serial.println(url);
"Accept: text/html\r\n" +
"Accept-Encoding: identity\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
Serial.println("Delaying for response") ;
int getDelay = 0 ;
while ((!client.available()) && (getDelay++ < 1500) ) {
delay(10);
String line = "" ;
//Serial.println("Begin http Response") ;
while(client.available()){
line = client.readStringUntil('\n');
//Serial.println(line);
//Serial.println();
String acState = line ;
Serial.println("End http Response") ;
//Serial.println("Closing http connection");
client.stop() ;
Serial.print("HVAC State: ") ;
Serial.println(acState) ;
if (acState == "cooling") {
Serial.println("HVAC cooling, check vibration sensor to see if window AC is running") ;
if (!acRunning()) {
powerAC() ;
} else if (acState == "off") {
Serial.println("HVAC off, check vibration sensor to see if window AC is off") ;
if (acRunning()) {
powerAC() ;
} else {
Serial.println("Can't get HVAC status") ;
Serial.println("Deep sleep: 20 seconds") ;
ESP.deepSleep(20000000,WAKE_RF_DISABLED) ;
delay(5000);
//delay(60000) ;
// Never get here
Serial.println("In main loop - shouldn't be here, resetting") ;
delay(5000) ;
ESP.restart() ;
And here is the results:
Connecting to wifi-ssid
.6.6.6.6.6.6.6.6.6.6.6.3
WiFi connected
IP address: 192.168.1.121
Connecting to: sync-nest.appspot.com
Requesting URL: /nest-thermostat-status.php
End http Response
HVAC State: cooling
Sensor Average: 37
AC is Off
<boot noise>
WiFi connected
End http Response
HVAC State:
Any thoughts?
