By zioax
#29328 Hi, Im tring to use an ESP-01 with the Arduino IDE 1.6.5, I've uploaded the example sketch WifiWebServer but the serial monitor don't output nothing! Tried with 6900 and 115200 baud rate. Whats the problem?
Thanks
By zioax
#29345 I'm using a cp2102 usb converter, the only connection is ch_pd to ground. The code, as written, is WiFi webserver in the examples sketchs
By Barnabybear
#29346 I recomend:
Vcc -> 3.3V
CH_PD -> 3.3V
Reset -> 3.3V
GPIO 0 -> 10K resistor -> 3.3V
GPIO 2 -> 10K resistor -> 3.3V
GND -> GND
Tx -> Rx
Rx -> Tx
To flash leave resistor in place, short GPIO 0 to GND and power cycle.
