By freedom2000
#29375 Hi,
I try to use SPI bus at a different speed than default settings.
I use the following code to set up the MaxSpeed
Code: Select allvoid setup()
  // initialize SPI:
  SPI.beginTransaction(SPISettings(100000, MSBFIRST, SPI_MODE0));
  SPI.begin();
The compilation is OK but it has no effect on the clock frequency which is still 1MHz
Could you please help me ?
Thanks
JP
