Servo motor is not running
Posted: Sat Sep 19, 2015 10:46 pm
Has anyone successfully run a servo motor (GWS S35/STD) with the nodemcu v1.0 and using arduino code?
I've connected as follow:
Servo signal to nodeMCU v1.0 GPIO 14 (I've tried other GPIO2 and GPIO9 before but no response)
5V supply from voltage regulator
Common ground between nodemcu and voltage regulator
I've tried changing to another servo and also changing my 9V supply to my voltage regulator but the servo motor doesn't seems to run.
I've tried the code on Arduino Yun before and the servo can run.
Anyone has any clues?
