By misterdanb
#29794 If I try to send UDP packets in my sketch, I have to put a delay(2); (below 2 does not work) into my loop function, otherwise the packet is never sent. If I put any delay directly after the endPacket(); call in the if condition (see below) it does not help at all, it has to be directly in loop.
As the code is somehow time critical, It would be awesome to omat those delay calls.
Any ideas?
Code: Select allvoid sendMessage(char message[])
#ifdef DEBUG
    Serial.print("Sending data: ");
    Serial.write(message, 5);
#endif
    udp.beginPacket(gameServer, gamePort);
    udp.write(message, 5);
    udp.endPacket();
void sendButtonsChanged(int newButtonStates)
    char message[] = {
        CMD_BUTTONS_CHANGED,
        char(newButtonStates & 0xFF),
        char((newButtonStates ^ buttonStates) & 0xFF),
        0x00,
        CMD_BUTTONS_CHANGED
    sendMessage(message);
void sendKeepAlive()
    char message[] = {
        CMD_KEEP_ALIVE,
        char(buttonStates & 0xFF),
        0x00,
        0x00,
        CMD_KEEP_ALIVE
void setup()
#ifdef DEBUG
#endif
    Cytrill.begin();
    setupWifi();
void loop()
    static int keepAliveCounter = 0;
    int newButtonStates = Cytrill.getButtons();
    if (newButtonStates != buttonStates)
        sendButtonsChanged(newButtonStates);
        buttonStates = newButtonStates;
    if (keepAliveCounter == 2000)
        sendKeepAlive();
        //delay(20); // not helping at all
        keepAliveCounter++;
    delay(2); // helps
    Cytrill.loop();
Thanks in advance,
misterdanb
