By Daemach
#31332 Is anyone working on a way to have the module download and update its own firmware from a website? Checking for newer versions on startup and automatically updating would really be slick... I assume it would have to download the image first then reset and the bootloader would do the update.
By Mmiscool
#31470 I was asking the same question not too long agoe.
Have not managed to get it working yet but the thread was over here.
I believe you will need the latest staging version to attempt to get it working and if you have an esp 12 with the 4 mb flash you might get better results than me.
Please post up your code if you get it working as I am keen to get it going with one of my projects.
http://www.esp8266.com/viewtopic.php?f=32&t=4903&start=0
By schufti
#33686 this "physical pin" is needed to get into the "boot loader" that allows flashing via serial.
If the SDK provides routines to access the flash memory, this is _another_ way to flash.
