Is favicon.ico request causing server to stick in while loop
Posted: Mon Oct 26, 2015 6:06 am
Hi, I’m running the following code from IOT-playground. All mostly runs as expected until I’m unable to connect to send requests. This happens every time I run the code, the only variable is the length of time before it becomes unresponsive.
I added some Serial.prints to debug. The code is getting stuck in the ‘while(!client.available())’ statement.
I commented the '// Wait until the client sends some data' block out & have not had the problem since. If for some reason a request is received that it doesn’t like it falls through to ‘Serial.println("invalid request");’., which is not a problem.
From debugging I noticed that when the code became unresponsive it was always just after a valid request. With this block commented out I now frequently get an ‘invalid request’ directly after a valid one. Which I believe is a 'favicon.ico' request.
Is it possible that the ‘favicon.ico’ request was causing the code to stick in the ‘while(!client.available())’ statement?
Is this the nature of the ‘favicon.ico’ request or the coding?
Any thoughts on the best way to correct this?
Thanks.
* This sketch demonstrates how to set up a simple HTTP-like server.
* The server will set a GPIO pin depending on the request
* http://server_ip/gpio/0 will set the GPIO2 low,
* http://server_ip/gpio/1 will set the GPIO2 high
* server_ip is the IP address of the ESP8266 module, will be
* printed to Serial when the module is connected.
const char* ssid = "your-ssid";
const char* password = "your-password";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
delay(10);
// prepare GPIO2
pinMode(2, OUTPUT);
digitalWrite(2, 0);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
// Start the server
server.begin();
// Print the IP address
if (!client) {
return;
Serial.println("new client");
while(!client.available()){
delay(1);
Serial.println(req);
client.flush();
// Match the request
int val;
if (req.indexOf("/gpio/0") != -1)
val = 0;
else if (req.indexOf("/gpio/1") != -1)
val = 1;
else {
client.stop();
return;
// Set GPIO2 according to the request
digitalWrite(2, val);
client.flush();
// Prepare the response
String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
s += (val)?"high":"low";
s += "</html>\n";
// Send the response to the client
client.print(s);
delay(1);
Serial.println("Client disonnected");
// The client will actually be disconnected
// when the function returns and 'client' object is detroyed
if (!client) {
return;
while(!client.available()){ //<<<<<<<<< gets stuck in loop here
delay(1);
Serial prints.
GET /gpoi/0 HTTP/1.1
Client disconnected
GET /favicon.ico HTTP/1.1
Invalid request
Thanks.
