ESP8266-12 newbie... cable and connect...
PostPosted: Wed Nov 04, 2015 12:14 pm
by smartgatto
Hello, my name's Marco and I am a newbie with this module... I have an ESP8266-12 connected to my pc with a FTDI board.
I try to upload on it nodeMCU firmware and seems it's all OK, but when I try to upload an example sketch (by arduino board), it upload the sketch but when I open serial port I can't see nothing.
The sketch is this:
const char* ssid = "Netgear";
const char* password = "password";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
  delay(10);
  // prepare GPIO2
  pinMode(2, OUTPUT);
  digitalWrite(2, 0);
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  Serial.println(req);
  client.flush();
  // Match the request
  int val;
  if (req.indexOf("/gpio/0") != -1)
    val = 0;
  else if (req.indexOf("/gpio/1") != -1)
    val = 1;
  else {
    Serial.println("invalid request");
    client.stop();
    return;
  // Set GPIO2 according to the request
  digitalWrite(2, val);
  client.flush();
  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
  s += (val)?"high":"low";
  s += "</html>\n";
  // Send the response to the client
  client.print(s);
  delay(1);
  Serial.println("Client disonnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is detroyed
My ESP connection:
VCC>3.3v
CH_PD>3.3v
TX>Rx (FTDI)
RX>Tx (FTDI)
GPI00>GND
GPI015>GND
GND>GND
It's all correct?
Thank you!
Re: ESP8266-12 newbie... cable and connect...
PostPosted: Wed Nov 04, 2015 2:15 pm
by brutzler
Hi,
look at Niels Book: http://neilkolban.com/tech/wp-content/uploads/2015/08/The-ESP8266-Book-August-2015.pdf
Page 16 and 17
BTW: Try a NodeMCU. Its an ESP8266-12E with the whole roundabout. You only need to connect to USB-Port.
The chineseman takes less than 8 EUR.
PostPosted: Thu Nov 05, 2015 3:51 pm
by smartgatto
Ok...thank you... I order a NodeMCU (10 euro).
while the time it will arrive, I try to continue to use my ESP8266-12.. I re-do all the connection and now it is ok, BUT.....
If I set the FTDI-usb at 3.3v the ESP don't boot, instead if I set the FTDI at 5v the ESP boot and connect to my router but it is so hot.. so I must stop experiment...
I don't understand...
how can it's possible???
PostPosted: Fri Nov 06, 2015 7:08 pm
by brutzler
Maybe this thread will answer your questions?
http://www.esp8266.com/viewtopic.php?f=32&t=3686
