Normaly I would choose the right board (NodeMCU 1.0), but actually testing with OTA, I am forced to take the generic-Board, because of its options "serial<->OTA"
In older packages, I modified the boards.txt. I created a second Generic ESP8266-Module with the change from "generic.upload.resetmethod=ck" to "generic.upload.resetmethod=nodemcu"
But always on changing to a new release, this options get lost. And if I forget to change again, I am struggling on download
This time, I was going a different way: I made the resetmethode switchable. (hope I understood the menu-structure correct)
menu.UploadSpeed=Upload Speed
menu.CpuFrequency=CPU Frequency
menu.FlashSize=Flash Size
menu.FlashMode=Flash Mode
menu.FlashFreq=Flash Frequency
menu.UploadTool=Upload Using
menu.Resetmethod=Reset Methode <-------------------- adding this line
generic.name=Generic ESP8266 Module
generic.upload.tool=esptool
generic.upload.speed=115200
generic.upload.maximum_size=434160
generic.upload.maximum_data_size=81920
generic.upload.wait_for_upload_port=true
generic.serial.disableDTR=true
generic.serial.disableRTS=true
generic.build.mcu=esp8266
generic.build.f_cpu=80000000L
generic.build.board=ESP8266_ESP01
generic.build.core=esp8266
generic.build.variant=generic
generic.build.flash_mode=qio
generic.build.spiffs_pagesize=256
generic.menu.Resetmethod.CK=ck <-------------------- adding this line
generic.menu.Resetmethod.CK.upload.resetmethod=ck <-------------------- adding this line
generic.menu.Resetmethod.NodeMCU=nodemcu <-------------------- adding this line
generic.menu.Resetmethod.NodeMCU.upload.resetmethod=nodemcu <-------------------- adding this line
generic.menu.UploadTool.esptool=Serial
generic.menu.UploadTool.esptool.upload.tool=esptool
generic.menu.UploadTool.espota=OTA
generic.menu.UploadTool.espota.upload.tool=espotaBut on changing the release, this will got lost again.
Wouldn't it be an option to implementate this in the boards.txt for further releases?
ESP8266 Arduino add-on
Arduino IDE 1.6.5
