By FOXi
#33504 Hi,
I am trying to get response from my web server(Raspberry) via HTTP GET method, but I don't see any reply on my client serial monitor (ESP).
const char* ssid     = "Pi_AP";
const char* password = "Raspberry";
const char* host = "data.sparkfun.com";
const char* streamId   = "1/";
IPAddress server(192, 168, 2, 1);
  delay(10);
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
int value = 0;
  delay(5000);
  ++value;
  Serial.println(host);
  WiFiClient client;
  const int httpPort = 8000;
  if (!client.connect(server, httpPort)) {
    return;
  // We now create a URI for the request
  String url = "/start/";
  url += streamId;
  Serial.println(url);
               "Host: 192.168.2.1" + "\r\n\r\n");
               //"Host: " + host + "\r\n" +
               //"Connection: close\r\n\r\n");
  delay(10);
  while(client.available()){
    Serial.print(line);
My request successfully reach the server because function on my server is executed.
Web server is working correctly I test it from terminal
Code: Select all$ curl -i -X GET http://192.168.2.1:8000/start/1/
HTTP/1.1 200 OK
Server: gunicorn/19.3.0
Date: Sun, 08 Nov 2015 22:59:59 GMT
Connection: close
Transfer-Encoding: chunked
X-Frame-Options: SAMEORIGIN
Content-Type: text/html; charset=utf-8
<!DOCTYPE html>
<html lang="en">
<head>
Output from my serial monitor is here:
Can you help me? Why I don't see response from server in my serial monitor?
By martinayotte
#33548 Did you try to simply place a longer delay instead of your delay(10) ?
Normally, it would be better to wait for a response instead of a delay, and check for timeout if no response at all.
Here is what I'm usually doing :
Code: Select all  int timeout = millis() + 5000;
  while (client.available() == 0) {
    if (timeout - millis() < 0) {
      Serial.println(">>> Client Timeout !");
      client.stop();
      return;
  while(client.available()) {
    Serial.print(line);
By FOXi
#33619
martinayotte wrote:Did you try to simply place a longer delay instead of your delay(10) ?
      client.stop();
      return;
    Serial.print(line);
It's working now. Thanks.
By bubba198
#34136
martinayotte wrote:Did you try to simply place a longer delay instead of your delay(10) ? Normally, it would be better to wait for a response instead of a delay, and check for timeout if no response at all. Here is what I'm usually doing :
martinayotte you are a life saver.
Thank you! I was missing characters due to the server responding to the GET request in a very fragmented fashion (who knows why) and so now it does take longer to assemble the response as far as my code is concerned but the response is 100% reliable.
!B
