By WalfasProject8
#34591 I have an issue loading a lua script programmed into an ESP via ESPlorer. I want to load it, first on the serial monitor, and then load it into an Arduino sketch.
Here's the code when I try to load the program on serial monitor:
Code: Select all#include <SoftwareSerial.h>
const byte rxPin = 3; // Wire this to Tx Pin of ESP8266
const byte txPin = 2; // Wire this to Rx Pin of ESP8266
// We'll use a software serial interface to connect to ESP8266
SoftwareSerial ESP8266 (rxPin, txPin);
  Serial.begin(9600);
  ESP8266.begin(9600); // Change this to the baudrate used by ESP8266
  delay(2000); // Let the module self-initialize
  while (Serial.available()){
     String Data = ESP8266.readStringUntil('\n');
     ESP8266.println(Data);
  while (ESP8266.available()){
     String inData = ESP8266.readStringUntil('\n');
     Serial.println("Got reponse from ESP8266: " + inData);
When I run this, I go to serial monitor and I write "dofile('server.lua')". It should show the IP of the ESP module, but it shows nothing at all. I already checked the baudrate of the serial monitor. Any help is aprecciated
By Mmiscool
#34601 I am a bit confused here. You can't run lua scripts from inside the arduino environment.
Arduino environment allows you to create truly compiled applications. You upload to the esp by fully re-flashing the module.
