By StrikerofDeath
#34765 Hi, i have one esp-01 but can not upload through the Arduino IDE
warning: failed espcomm_sync
error: failed espcomm_open
with "ESP_DOWNLOAD_TOOL" I can flashing without any problem, but the speed is 230400 and the Arduino does not exist this option.
By aortiz557
#34768 I used a separate teensy3.0 as a usb to serial adapter while waiting for my real one to come in, i set the baud rate to 115200 when programming. Are you pulling down GPIO_0 and resetting it before programming?
By forlotto
#34799 May want to double check everything hardware wise with this diagram.
http://www.esp8266basic.com/flashing-instructions.html
